Proper liner/head spacing for Nelson QM40
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> QM-40 Racing >> Proper liner/head spacing for Nelson QM40
Page: [1]
Login
Proper liner/head spacing for Nelson QM40 - 7/5/2006 4:20:21 PM
jprge C.
Status: offline
Hello,
Thank you for the information with the spinner for the Nelson. Can someone please tell me the correct shim set up for the nelson. I measure the engine with out shims, the head measures .185 and the liner to the top of the piston is .186" The shim under the liner when I got the engine was .010" and under the head was .003" Does this sound like a proper setting. I am using the new lighter pitch CF quarter midget APC prop.
Jorge
       Post #: 1
RE: Proper liner/head spacing for Nelson QM40 - 7/5/2006 5:31:22 PM
garys
Status: offline
That sounds good to start, each engine has its own characteristics and they don't all run with the same settings. Did you get the engine new from Dave Shadel? If so, why did you bother to take it apart? Dave's already test ran it and has it set properly so there isn't a need to take it apart.
_____________________________
GS
(in reply to jprge C.)
       Post #: 2
RE: Proper liner/head spacing for Nelson QM40 - 7/5/2006 10:54:31 PM
Ed Smith
Status: offline
Gary and I will never agree on this. I recommend that a new engine should always be taken apart and washed out. Rarely have I washed out a new engine and NOT found aluminum chips in the bowl.
The measurements quoted will give 0.196 deck height and 0.014 head clearance.
The two Q40s I purchased last year had 0.196 deck height and 0.017 head clearance. Yours may be a little tight.
However, as Gary stated, not all engines run the same. You will have to fly it and try it. Make some changes, it is a learning process.
Ed S
(in reply to garys)
       Post #: 3
RE: Proper liner/head spacing for Nelson QM40 - 7/5/2006 11:20:16 PM
daven
Status: online
I've done it both ways, they all vary a little. I personally like to take them apart and measure myself, but I put trust in Dave on my two engines this year, and both seem to be working well, so what do I know.
I typically run .196 and .016 on Q40 motors, many are running closer to .193/4 and .013/.014.
Dave Norman
klasskote.com
supertrc.com
(in reply to Ed Smith)
       Post #: 4
RE: Proper liner/head spacing for Nelson QM40 - 7/6/2006 2:48:23 PM
diggs_74
Status: offline
I always thought that the tighter the head the harder it was to needle... I don't know if that's true across the board but I know it is with one of my quickie motors... It seemed to make it really finicky...
Lee LaValley
NMPRA# 33w
(in reply to daven)
       Post #: 5
RE: Proper liner/head spacing for Nelson QM40 - 7/6/2006 3:31:55 PM
daven
Status: online
a tighter motor will be more finnicky to needle, but can also be faster.
Take your tradeoffs, I prefer an engine that I can consistenly get a good needle.
< Message edited by daven -- 7/6/2006 3:33:00 PM >
Dave Norman
klasskote.com
supertrc.com
(in reply to diggs_74)
       Post #: 6
RE: Proper liner/head spacing for Nelson QM40 - 7/6/2006 3:41:04 PM
diggs_74
Status: offline
I don't have a lot of experience with these yet so I prefer to make at easy as possible...
Lee LaValley
NMPRA# 33w
(in reply to daven)
       Post #: 7
RE: Proper liner/head spacing for Nelson QM40 - 7/6/2006 4:47:20 PM
Super Splatter
Status: offline
quote:
ORIGINAL: diggs_74
aka.... I'm from Wisconsin
       Post #: 8
RE: Proper liner/head spacing for Nelson QM40 - 7/6/2006 5:48:39 PM
diggs_74
Status: offline
I should have seen that coming...
Lee LaValley
NMPRA# 33w
(in reply to Super Splatter)
       Post #: 9
RE: Proper liner/head spacing for Nelson QM40 - 7/6/2006 7:17:59 PM
daven
Status: online
A beer in one hand, a caliper in the other, you'll figure it out in about 2 hours
Then again, who am I to judge
Dave Norman
klasskote.com
supertrc.com
       Post #: 10
RE: Proper liner/head spacing for Nelson QM40 - 7/6/2006 8:13:44 PM
diggs_74
Status: offline
Everything goes better with beer
Lee LaValley
NMPRA# 33w
(in reply to daven)
       Post #: 11
RE: Proper liner/head spacing for Nelson QM40 - 7/7/2006 2:42:11 AM
jprge C.
Status: offline
Hello,
I bought the engine and airplane brand new at a swap meet back in late April. I have just had to work so many hours it is only now I am getting to work on it. The engine is brand new, I even have the paperwork and the credit card reciept was along with it. It was bought from Nelson Competition Engines, PA in 2004. The reason I took the engine apart is going by what Terry Prather allways said, "it can't hurt if you are careful and you might find something I missed"
I left the engine alone and ran it with an FAI prop I had that I cut down to 7". After 5 runs like that I put the CF APC prop, the 7.8x8 I believe and it turns 22,800 and will pinch to 23,700. Friday I hope to fly it and will report the results.
Jorge
       Post #: 12
RE: Proper liner/head spacing for Nelson QM40 - 7/7/2006 2:51:38 AM
daven
Status: online
If your getting those kind of rpms, your doing better than me
Dave Norman
klasskote.com
supertrc.com
       Post #: 13
RE: Proper liner/head spacing for Nelson QM40 - 7/21/2006 4:20:49 PM
jprge C.
Status: offline
Hello,
Well I now have 6 flights on the plane and engine and it really goes quite well. I was hoping to take it to Bowie, but I have found the race has been cnceled. I will have to wait until next year to get a true comparison on how well it does go. The Nelson is very easy to run and the final set up with the shims has ended up at .009 under the liner and .003 under the head. It needles well and runs perfect through the tank.
Jorge
(in reply to daven)
       Post #: 14
RE: Proper liner/head spacing for Nelson QM40 - 8/3/2006 12:46:21 AM
SmokinJoe
Status: offline
Deleted.
Joe Luxford
Hamilton
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
