bigR
CA, USA Status: offline
John, I was thinking along the same lines. The newer computer radios enable you to mix any channel to another and switch the mix on and off. Since I have a number of older, reliable non computer radios, I was thinking of another way to selectively mix or not mix the throttles with the rudder. Use an elevon mixer to combine the rudder and throttle functions. The trainer switch sounds like a good idea but then you have to hold it with one hand while steering with the other. Since the trainer switch is usually on the left side, and the rudder and throttles are also this could make for awkward contortions. The retract switch could be used to switch the mix on and off. Gear down, mix on, in the air no mix. If I get the time I will breadboard a circuit to do the on/off mixing function. Would take a couple of IC's and a few resistors, caps, etc. I design electronic stuff also. Too many hobbies.... OTOH, maybe I could save this for later in the year and just buy a new radio. Really want to get to building that Emily. Should I start a new thread? This one is for YOUR plane, which is really a great accomplishment. Already went to the local 99 cent discount store and bought a jar of mayo for the plastic container. I compared the diameter with that of the cowls on the plans John sent me. Both were about 2.8 inches. The 7-inch 3-bladed prop looks good with enough blade area outside the cowl to be effective. This dimension is close to the plans also. Don't know about the mayo, some off brand. Hope it doesn't clog the plumbing. John in Kalifornia
