noximus
CA, USA Status: offline
quote:
My prospec is not a race motor and I wont argue that, but I will bet money there is not another big block made that will beat me in a drag race... I am going to video me beating a fellows Nova 28 very soon, both will be in truggies to keep things more planted... Your going to be shocked to see the truth... The Prospec is a flat out monster plain and simple. i have seen engines that flat out have less power than the other beat any engine out there. if you dont have a certain engine tuned properly, pipe/header combo, it wont be at its potential. i KNOW how the SH .28 runs, i have seen it run before, its not a shocker man, it honestly does not have anything on the 528, im sorry. i also know how the 528 can be and is, i have beaten a 528 on the straight, reason being, the said individual was using a 13t clutchbell, so the engine winded out before it even got half way down the straight, i garuntee if he geared his 528 properly, he would have lit me up and down the straight hands down. your videos are flawed man, if you want to test these engines HONESTLY with true results, you have to check out some of these drag races you can see out in texas or in southern california. they flat out run these motors into the ground, no cooling heads or anything. if that isnt a test, then i dont know what is. a couple of wheelies in the parking lot just doesnt prove anything, i can gear my trug to do that as well. thats not an accurate assesment on how to determine which does and doesnt have more power than the other. check it out: http://www.putfile.com/pic.php?img=3049263 http://www.putfile.com/pic.php?img=3049189 and here is a vid of a drag car using a novarossi .21 on-road engine. which BTW looks allot faster than your drag race vid. http://media.putfile.com/Broke-in-the-1st-round-a-heartbreaker the way these guys put these motors to test, is probably more brutal than what most of us can do. and believe it or not, these motors are lasting 4 to 5 gallons.
