Steve Campbell
LA, USA Status: offline
Since you have zippo LHS support over there (unless something has changed that I'm not aware of), your best bet is to get what your local guys are flying. Last I heard, that was the Raptor. Judging from your user name, you know Mike, yes? If you aren't hooked up with those guys, or just want to be different, I would go with the Sceadu. It is a bit larger than the average 30, but definitely not a lead sled. And there is no controversy over parts availability. Since you'll be doing all mail-order anyway, pick your vendor. Actually, I think the Shuttle is a better "starter" ship. but I hesitate to recommend one to a raw beginner, for this reason: The Shuttle has been around since the mid-80s. The current iterations of the model still use many original parts. The molds for these are getting long in the tooth, and produce parts that need quite a bit of "tweaking" before they get smooth. This is no big deal- IF you know what to do. But the last one I helped a guy with (a Challenge- Hirobo's basic entry level offering) needed a LOT of tweaking, especially on the bellcranks, to get right. A newbie who doesn't know what to look for and correct would have problems. But the Challenge comes with a most excellent training gear set-up, and that saves you the extra expense of a Roto-Pod. I am no fan of el cheapo dowels tie-wrapped to the skids; but lots of folks have learned on such an arrangement. My big gripe with the Challenge is the tail rotor pitch change mechanism. It is the original, and it sucks. It works, but just. I'm preparing to get an entry-level plastic machine for my grandson, so I'm going through the "what to get" quandary myself. I have enough old Concept parts, frames, etc., to build one for him. But I want to keep that "stash" intact to keep mine flying... I can't decide between a Sceadu or a Shuttle Challenge. What I'll probably end up doing is get the Challenge and the parts to put a decent tail box on it. The best advice I can give you is GET HELP. If you have difficulty hooking up with the guys over there, I'll be glad to work with you if you don't mind the drive to Baton Rouge. But you're smart to do some research before you buy. Another consideration is your radio. If you have someone available who can buddy-box you, then by all means get that brand of radio. And get the best radio you can. I would suggest nothing less than a Futaba 9C or JR 8103. JR has a new nine-channel (9X?) that the US distributor hasn't admitted exists yet, but it is out there. Buddy boxing is great. It will get you past the initial terror of crashing your new toy, and give you the confidence to practice on your own. Oh, you'll still have the opportunity to crash by yourself; but at least you will already have hovered the bird and KNOW that it flies just fine, as long as you do your part... Steve
