RE: Neptune ARF advice on 1st seaplane? Construction tips?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> RE: Neptune ARF advice on 1st seaplane? Construction tips? Page: <<   < prev  1 [2]
Login
RE: Neptune ARF advice on 1st seaplane? Construction tips? - 6/4/2007 4:10:39 AM
daviddep
Status: offline
I'm thinking about a first sea plane. I have an OS 70 Surpass. Did that engine work well for you? I'll either buy the Mariner II by Lanier or the Neptune. Your thoughts?
quote:
ORIGINAL: foresterxt
I cracked open the box to my new Neptune. Very impressed! I'm was contemplating using an OS .70 fourstroke but after reading various comments about the pylon not be tall enough/strong enough I wasn't sure. Well I must say, the pylon is actually very sturdy. Its's fully laminated hardwood (not a built up box type of pylon). It's also very tall. I slid it all the way into the fuselage and I measured roughly 7.5 inches from the middle of the engine mount holes to the fuselage, plenty of room for up to a 14" prop...crazy. Looks like the .70 and 13x6 prop are going to fit the bill perfect.
(in reply to foresterxt)
       Post #: 26
RE: Neptune ARF advice on 1st seaplane? Construction tips? - 6/4/2007 4:30:02 AM
Brew07
Status: offline
I got about 10 flights on mine now. I have to say the .46ax I am using is more than enough, it has a lot of speed and is vertical clime is great! I belive I am a bit tail heavy and will check the cg again. It likes to balloon up when the trottel is cut back to land it dose settle after a few seconds. Fun plane though
       Post #: 27
RE: Neptune ARF advice on 1st seaplane? Construction tips? - 6/21/2007 3:05:50 AM
lil abner
Status: offline
[8SKYPILOT, PUT TOGETHER A NEPTUNE WITH A MAGNUM 4-STROKE 70. THE PROBLEM IS THE ENGINE THRUST IS 3/8 OF AN INCH OF TO THE LEFT AND NOT IN THE CENTER OR A LITTLE BIT TO THE RIGHT LIKE MOST LAND R.C. PLANES. MY FIRST SEAPLANE AND DON'T WANT TO CRASH IT. THANKSD]
(in reply to SKYPILOT)
       Post #: 28
RE: Neptune ARF advice on 1st seaplane? Construction tips? - 1/30/2008 12:39:22 PM
James1v12
Status: offline
I am looking to get the Neptune! What do you thing about the OS55AX or should I stay with the 46ax.
Let me know.
Thanks Train Driver
Click to see fullsize image.
Click for fullsize
(in reply to daviddep)
       Post #: 29
RE: Neptune ARF advice on 1st seaplane? Construction t... - 3/24/2008 2:35:50 PM
ekfinch
Status: offline
I have just completed my Seamaster and it is a terrific looking plane. I am excited about flying it on Lake Lanier. Everything I have read on the forum reinforces my choice for this plane. Everything I have read here leads me to believe they are easy to land and can do aerobatics, which would be cool at the lake. Any advice anyone who has actually flown one would be helpful so that I do not crash on my first flight. I am going to check it out on land first and make sure all is working well and adjusted. THe kit had two left rear landing gear so I am waiting on a replacement for one of them. They don't seem to be interchangeable.
One question. The tail assembly seems to be very weak. Mind sort of shakes with any pressure. I am concerned that if I do any kind of aerobatics, it will come off. Has anyone done in mods to reinforce the tail.
Thanks for you help.
       Post #: 30
RE: Neptune ARF advice on 1st seaplane? Construction tips? - 3/24/2008 3:13:49 PM
Brew07
Status: offline
I have a 46ax in my Neptune with a 10x6 APC prop and it has plenty of power for this plane. I don't think it would be worth spending the extra $ on the 55ax.
(in reply to James1v12)
       Post #: 31
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.734RCU4
