RE: ANYONE FLY JR VENTURE ?
Tower Hobbies
Logged in as Guest
  Printable Version
Thunder Tiger Raptor 50 SE - RTF
Seller:  dasmonkeyboy
Details:   $1,200.00   |  12/9/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> RE: ANYONE FLY JR VENTURE ?
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: ANYONE FLY JR VENTURE ? - 7/12/2006 3:23:18 PM
BarracudaHockey
Status: offline
Bulldog adhesion promotor works well on those canopies to get paint to stick.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to james199)
       Post #: 26
RE: ANYONE FLY JR VENTURE ? - 7/13/2006 2:06:07 AM
james199
Status: offline
NOW I HAVE A PROBLEM ?? i hooked up the overnight charger and did a 12 hour charge checked everything at the house then went out to fly as i was hovering my first tank i wasa doing a side hover and noticed my volt meter and it was on the last green dot moving into the yellow ?? i promply landed and sure enough it was low on charge my new burning question is how long should a RX battery last ?? it is the factory battery i have only had my venture for less than a month i know it has do a lot of work but dang i would think it would last at least 3 tanks of fuel ....not 1 and die....right ??
Remember what goes up must come down !
(in reply to BarracudaHockey)
       Post #: 27
RE: ANYONE FLY JR VENTURE ? - 7/13/2006 10:28:45 PM
jez33
Status: offline
what size battery you have?
if you have digital servos on your heli on all surfaces then that can drain quite a bit of power. i dont fly any of my helis with less then a 1500mah even with only standard gear on it. if you were using digital on nick and roll aswell as gyro/tail then i wouldnt go below 2500mah but i mostly fly on 3000mah any way..
if your battery is within the above then perhaps your battery is new and needs a few charge cycles through it but even in a brand new state it still sounds a bit quick to go to red as yours did so fast...
are you happy that your charger is working correctly ?
       Post #: 28
RE: ANYONE FLY JR VENTURE ? - 7/13/2006 11:19:14 PM
james199
Status: offline
quote:
ORIGINAL: jez33
its a 1100 mah the servos are not digital but i thought i should get more than 1 flight before it dies anyhow i just ordered a 2500mah battery today i also thought i would ask the lhs if thy would replace it for me as it is new but anyhow this time next week a new power plant will be in there
(in reply to jez33)
       Post #: 29
RE: ANYONE FLY JR VENTURE ? - 7/14/2006 6:25:27 AM
BRADI
Status: offline
I use 3000 miliamp sub C cells. A bit heavy but I don't have to worry as much anymore. Further, I run nav lights and co-pilot on my Venture so I'm consuming a little more power than the average heli.
       Post #: 30
RE: ANYONE FLY JR VENTURE ? - 7/14/2006 8:56:04 AM
jez33
Status: offline
as you say a 1100 mah battery should last longer then that..
which charger do you use ? if your using a standard charger they dont fully charge a 1100 mah untill roughly 24 hours.most standard slow chargers only give out between 50 to 75mah.
idealy for a slow charger it should be able to slow charge at one tenth of the mah of the battery,
so if you have a 1000mah battery then a slow charger giving out 100mah is ideal..but you can be forgiven for thinking that you need 10 hours to slow charge a 1000 battery but in fact you need to give the battery half as much time again as there is a little wastage in the cells when charging them and some of the amps you put in turn to heat and isnt reserved in the pack so you need 15 to 16 hours charge time..
(in reply to BRADI)
       Post #: 31
RE: ANYONE FLY JR VENTURE ? - 7/15/2006 1:57:46 AM
james199
Status: offline
DAMN !! i just came in to find the RX pack HOT as hell i guess the its took a crapp i was going to do some flying late today but i guess not ...i had it on the slow charge (24hr) looks like i wont be flying till i get another battery.....crapp i did a fast charge yesterday and it lasted for 1 tank of gas then RED .....man this just S%$^ i just get it going and now this .... i guess i will take it to the LHS and see if they will replace it tomorrow.
(in reply to jez33)
       Post #: 32
RE: ANYONE FLY JR VENTURE ? - 7/15/2006 2:23:38 AM
james199
Status: offline
well its been 35min and the thing is DEAD DEAD DEAD DEAD ....grrrrrr .in the yellow/red so its off to the LHS tomorrow.
       Post #: 33
RE: ANYONE FLY JR VENTURE ? - 7/16/2006 2:01:23 AM
james199
Status: offline
got a 2800 mah battery and its off to the WILD BLUE YANDER once more also had a small problem happen today as well the hose in the tank split and i lost all power it almost caused me to SPLAT BANG !! but i guess i am gatting better as i was able to land with only a little thud and NO BROKEN PARTS !! thats the best part now i cant wate till tomorrow
       Post #: 34
RE: ANYONE FLY JR VENTURE ? - 7/16/2006 6:45:19 AM
BRADI
Status: offline
quote:
ORIGINAL: james199
Sounds like your getting everything sorted out...that’s good. Keep an eye on your battery to switch connector. The Futaba connectors tend to wear out and you will eventually lose a connection and it will probably happen during FFF. I found this out the hard way...(twice). Change your connector when you get the chance, most people prefer dean connectors. I use dean's p.n. 1300. Load test your on board batteries as much as possible. I check before every other flight. I use a Futaba battery checker BR-2000. It will pay for itself in one crash. So many times I have been preoccupied with set-up and completely lost track of time, only to find out that I had minimal on board bat power for the test flight. (Scary stuff!)
Brad
       Post #: 35
RE: ANYONE FLY JR VENTURE ? - 7/16/2006 6:53:42 AM
BRADI
Status: offline
quote:
ORIGINAL: james199
Yup, the clunk line, (supply line) in the tank is cheap and has failed on many Venture heli's. For some unknown reason, JR uses cheap thin walled fuel supply lines in their heli's fuel tanks. It should be changed ASAP.
Brad
       Post #: 36
RE: ANYONE FLY JR VENTURE ? - 7/18/2006 10:17:46 PM
swheli
Status: offline
I am new to the forum..I started with a walkera 36,then progressed to an old Morley Maverick and now awaiting a second hand ventura 50 from ebay.So i was pleased to see some good comments on this heli.I have only bought the frame so look forward to installing engine,radio etc.
(in reply to BRADI)
       Post #: 37
RE: ANYONE FLY JR VENTURE ? - 7/19/2006 1:03:09 AM
james199
Status: offline
swheli : you will enjoy flight capabilities of your new used venture it will quickly become your all time favorite bird
(in reply to swheli)
       Post #: 38
RE: ANYONE FLY JR VENTURE ? - 7/20/2006 7:58:38 PM
swheli
Status: offline
it seems my ventura 50 is on the way ...can't wait!!!can anyone advise engines and mufflers that will fit ...since i am working to a bit of a budget cost and performance has to be balanced!!!Don't forget i am a bit of a beginer so not looking for something to do loops and rolls in the uper stratosphere.
thanks
David
       Post #: 39
RE: ANYONE FLY JR VENTURE ? - 7/21/2006 2:36:21 AM
