RE: ANYONE FLY JR VENTURE ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> RE: ANYONE FLY JR VENTURE ?
Page: <<   < prev  1 2 [3]
Login
RE: ANYONE FLY JR VENTURE ? - 8/3/2006 12:30:46 AM
BRADI
Status: offline
quote:
ORIGINAL: raston
O.K. so I going for the hyper. But I have read that on the venture, I will require a 'thrust washer/hub' (the aluminium hub that a propellor sits against in an aeroplane application) that is included on the non-hyper motor but not on the hyper version. Can some confirm that and if so, does anyone have the part numbers I will need to order. Or is there another way?
I can confirm that the thrust/hub you mentioned does not come with the hyper 50...at least one didn’t come with mine. Now that I think of it, it didn’t come with my OS 37 either. I would be surprised if one came with the non-hyper 50 versions.
(in reply to raston)
       Post #: 51
RE: ANYONE FLY JR VENTURE ? - 9/10/2006 3:06:41 PM
denandlissa
Status: offline
I FLY THE VENTURE 30 ALSO...HAS BEEN DOING GREAT ALL SUMMER ALTHOUGH I AM STILL IN THE HOVER MODE. I HAVE A FRIEND EXPERIENCED IN HELOS AND HE FLIES IT GREAT. ONE THING
I FOUND ABOUT TAIL WAG WAS MY ROTOR SPEED WAS TO HIGH. ONCE I TRIMED THE ENGINE DOWN A LITTLE IT DID FINE. ALSO MAKE SURE YOU HAVE THE REVO MIX IN YOUR TRANSMITTER TURNED OFF. NOT NEEDED WITH THE TAIL LOCK GYRO. HAVING AN OPTICAL TACH HELPS ALOT IF YOU HAVE ACCESS TO ONE. KIND OF EXPENSIVE TO BUY...ABOUT $80 BUCKS.
HAVE YOU BALANCED YOUR ROTOR BLADES.? I TRASHED THE WOODEN ONES AND BOUGHT A SET OF MAVRICK COMPOSITE BLADES.
(in reply to james199)
       Post #: 52
RE: ANYONE FLY JR VENTURE ? - 9/13/2006 12:53:51 PM
james199
Status: offline
yep the venture is a sweeeeeettttttttt bird each day i fly it i like it more than the day before and yes i always balance my blades i found that some aluminum tape that A/C people use is great for adding weight and it sticks GOOD its just a little flashie but hay iam
into bling bling
_____________________________
Remember what goes up must come down !
(in reply to denandlissa)
       Post #: 53
RE: ANYONE FLY JR VENTURE ? - 9/13/2006 4:28:23 PM
BarracudaHockey
Status: offline
OS did ship the 50sxh with the trust washer and woodruff key, the hyper ships without but you can order it if you need.
Den, typing in all caps is considered shouting, please refrain, also posts that are all caps are harder to read and more likely to get skipped over.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
       Post #: 54
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU4
