garys
CA, USA Status: offline
"Save us money? Not sure about that" Are you saying that when the manufactures save money by not having to buy contest grade balsa to get close to 3.5lbs, and save $5 per kit, that they aren't going to pass that on to the consumers? But that was going to save racing and make everybody be able to do it! We were going to have an explosion in new blood!! My only opposition of the weight increase was the reasoning. In my mind, none of the reasons was valid. Here are the ones I heard... 1. It would make it cheaper because people could use standard radio equipment. It won't. The manufactures will increase the weight of the bare airframs to save material costs and the time it takes to save every last ounce. 2. It would make it so that people building wood airplanes can meet minimum weight. People were making minimum weight wood airplanes before the composites came in, even with heavier radio equipment than we have available today. In fact, when the composites started, the ones flying them were pushing for weight increases so they wouldn't have a weight disadvantage to the wood airplanes...DID PEOPLE FORGET HOW TO BUILD? 3. Increasing the weight limit will level the playing field. Wrong. Increasing the weight of all the airplanes, if anything, will give a greater advantage to those that fly the smoothest and have the callers that can give the best launches. Lets watch Randy get more Nats wins I know the rule is going to pass. If somebody gave a good, logical reason for increasing the weight, I would've been happy to support it. I guess I should be happy, I feel I'm a good flyer, and my caller gives good launches, so it's going to work out to my advantage at times. Well, I'm off my soapbox and off to work... GS
_____________________________
GS
