RC sub made from scratch
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> RC Submarines >> RC sub made from scratch Page: [1]
Login
RC sub made from scratch - 7/7/2006 11:59:20 AM
diasje
Status: offline
Hello here i am again.
Is it possible to make something like this:
http://www.h2eye.com/image_gallery.html
This one its Controled with a cable, but is it possible to do something like this, a bit smaller and RC?
Has anyone done one?
This one is fine too:
http://www.geocities.com/navalrc/indexe.htm
As anyone done one of this.
Is there somewere one how to to this kind of sub?
< Message edited by diasje -- 7/7/2006 12:43:04 PM >
       Post #: 1
RE: RC sub made from scratch - 7/7/2006 5:21:51 PM
Captain Nemo12
Status: offline
quote:
ORIGINAL: diasje
That is one sweet-looking sub!!! If you wanted to build one alike I'd suggest to convert the existing model to RC, since being wire-controlled, it'll probably have the motors already installed, just drop in the RC-equipment and go. If you wanted to build a sub similar to the second one, you'll probably need simple-shaped objects, PVC tubes, plastic sphere covers, etc.
_____________________________
In the works: HL Panzer III, Type VIIb U-boat
(in reply to diasje)
       Post #: 2
RE: RC sub made from scratch - 7/19/2006 3:34:33 PM
diasje
Status: offline
Ok, i am sorry for not be here for so long.
I whant to now what kind of motor should i use for my sub?
For a first test i am thinking in bying one like this:
http://www.raidentech.com/rarecoubasun.html
http://www.egrandbuy.com/atrcmitosu.html
And i will make a new hull, and change the motor to a more powerfull one, is that possible?
(in reply to Captain Nemo12)
       Post #: 3
RE: RC sub made from scratch - 7/19/2006 5:12:30 PM
Captain Nemo12
Status: offline
Any motor that's powerful enough to propel the sub will be fine. The first sub is a copy of the Hobbico SeaScout, it uses a vertical thruster to dive the sub (just like the Walmart ones) and two seperate props for directional control. The second sub incorporates the same design as the Megatech Ocean Explorer and the Radio Shack Mako subs. Both subs are dynamic divers.
Only if you have the money and the guts to do it...
       Post #: 4
RE: RC sub made from scratch - 7/19/2006 5:39:47 PM
diasje
Status: offline
Can you or somenone, advise me on witch motor to choose?
The hull will be made in PVC.
Can someone, explain to me whats:
A servo, and what is it for
Are there any ballast kits already made avaiable to buy?
< Message edited by diasje -- 7/19/2006 5:41:51 PM >
       Post #: 5
RE: RC sub made from scratch - 7/19/2006 10:34:45 PM
Captain Nemo12
Status: offline
Hi,
The motor choice depends on several factors: the sub's size, battery, the torque, etc. Several manufacturers such as Graupner, Robbe, Mabuchi, Johnson, and Pittman make electric motors. I've never been familiar with brushless motors however.
A servo is a device attached to the receiver unit which does the physical work inside an RC vehicle. It is "the little black box" that has all the linkages and control rods hooked onto it. It has an electric motor and a gearbox which allows it to control all your control surfaces (e.g: rudder, diving planes, ballast tank valves, etc).
As for ballast tanks, several manufacturers make those, check these links out:
Pump-ballast system made by OTW:
http://www.otwdesigns.com/DiveSystems/divesystems.htm
Norbert Bruggen:
http://modelluboot.de/
Engel piston tank:
http://www.engel-modellbau.de/catalog/index.php?cPath=2_30&osCsid=c20005ec54b3642c5349a1b11b39c858
Some people also like to make their own ballast tanks, for several reasons: compatibility issues, price...... or just for the fun of out it!!!
< Message edited by Captain Nemo12 -- 7/19/2006 10:35:54 PM >
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU5
