Orion1024
IL, USA Status: offline
The #4 would be better suited to a beginner because it is easy and cheap to repair, but If you were choosing strictly between the 22E and 36, I would go with the 36. The 36 has a belt drive tail and separate gyro, both of which are a big improvement over the 22E. I've had my 36 for around a month now and it works very well...the only problem I've had was with the stock brushless motor getting too hot and breaking the shaft. If you go with the 36, I would get the one with a brushed motor and immediately replace it with a nice brushless setup...like a Castle Creations ESC and one of the Align motors. The cost of the heli + the brushless upgrade would set you back around $275. If that's too much, the 22E would be a good option too.
