fish tailing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> fish tailing Page: [1]
Login
fish tailing - 7/7/2006 11:13:38 PM
acheron
Status: offline
i'm new to drifting, as well as rc in general. i bought a tt-01 and put some abs tires on it. .. and i've come to realize that this is a bit trickier than it looks it was, at first, like running on ice. i was mostly just spinning, not really drifting. after some practice i was getting the car to drift nicely, but keeping control of the car after comming out of a corner is still escaping me. the majority of the time it was fishtail back and forth and spin out. i've tried letting off the throttle completely, as well as tapping it. releasing the stearing knob and giving it a touch of throttle seemed to work a little better, but nothing has worked consistently so far. Obviously i need some more practice but i was wondering if anyone had suggestions or pointers to push me in the right direction. My car is all stock except for an aluminum drive shaft and the abs tires.
oh and for any other newbies out there, here's what happens when you bake your abs tires too long My 2nd attempt worked much better...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by acheron -- 7/7/2006 11:16:37 PM >
       Post #: 1
RE: fish tailing - 7/7/2006 11:14:54 PM
ROYjovero
Status: offline
Why did you put the ABS in the oven in the first place?
(in reply to acheron)
       Post #: 2
RE: fish tailing - 7/7/2006 11:19:22 PM
acheron
Status: offline
the wheels were bigger than the abs. i put the tires in the oven for about 2-3 mins and they expanded just enough to slip in the rims. when they cooled, the wheels were secure in place. In my first attempt, i cooked them for about 5-8 mins and they melted all over the place.
(in reply to ROYjovero)
       Post #: 3
RE: fish tailing - 7/7/2006 11:21:05 PM
Spartan-Drifter
Status: offline
What Temp did you bake them at?
       Post #: 4
RE: fish tailing - 7/7/2006 11:25:07 PM
acheron
Status: offline
400 degrees. i pulled them out 2 or 3 times every 60 seconds until i could push the wheels in.
(in reply to Spartan-Drifter)
       Post #: 5
RE: fish tailing - 7/7/2006 11:25:31 PM
Yomillio
Status: offline
Ill I usually have to do is freeze the wheels overnight and put the tires in hot tap water then throw them together with a rubber mallet, its a pretty safe and effective way of doing it.
< Message edited by Yomillio -- 7/7/2006 11:27:35 PM >
_____________________________
CEN GX1... I love being different.
       Post #: 6
RE: fish tailing - 7/7/2006 11:25:48 PM
Spartan-Drifter
Status: offline
ok thx ill try that
       Post #: 7
RE: fish tailing - 7/7/2006 11:27:36 PM
ROYjovero
Status: offline
Damn what kind of ABS are y'all getting? Mine are usually a hair bigger than my wheels, so I have to wrap the inside of the wheel with tape to get a snug fit.
       Post #: 8
RE: fish tailing - 7/7/2006 11:30:09 PM
acheron
Status: offline
I didn't want to wait They turned out better than i expected actually. They're very secure, w/no gaps between the wheel and abs. now.. does anyone have any advice about how to control my car
(in reply to Yomillio)
       Post #: 9
RE: fish tailing - 7/7/2006 11:30:18 PM
Spartan-Drifter
Status: offline
Roy where do you get you ABS from?
       Post #: 10
RE: fish tailing - 7/7/2006 11:36:39 PM
ROYjovero
Status: offline
I get mine at any home improvement store, i.e. Home Depot, Ochard Supply Hardware, Lowe's, etc. Never had any fitment issues.
Now about your car control, you just need to keep practicing. There is no replacement for driving experience. And honestly, it might be an issue with your tires.
       Post #: 11
RE: fish tailing - 7/8/2006 12:17:55 AM
Auslide
Status: offline
I bake my PVC before fitting them to my Rims... No mess no glue and no problems...
Fan Force oven only With a good ventilation system
       Post #: 12
RE: fish tailing - 7/8/2006 3:04:00 AM
slideyourride90
Status: offline
dude its' probally an alingment problem( if the car is not going in a strait line when your not putting any steering input) or you just got to get used to the "feel" of the car, i've been into r/c touring car racing for about five years now and won sum races and the more you drive the better you'll get and the better you'll be to control the car, just get sum more driving hours under your belt and that should solve the problem
mugen mtx-4: os .12 tz/ futaba fasst/ jaco tires sidewinder fuels
serpent impact mt2: rex .15/ twister tires
(in reply to Auslide)
       Post #: 13
RE: fish tailing - 7/8/2006 4:39:32 AM
driftdriftdrift
Status: offline
abs is like ice when its new. once you get it worn in your drifts should be alot better
Do It Sideways Fool
(in reply to slideyourride90)
       Post #: 14
RE: fish tailing - 7/8/2006 4:52:49 AM
.ace
Status: offline
where did you buy your car from? and for how much? i love the body and also me friend has abs and all he did was drive it on the pavement and it worked fine, or weared down really fast :P
(in reply to driftdriftdrift)
       Post #: 15
RE: fish tailing - 7/8/2006 5:06:15 AM
acheron
Status: offline
yeah, the tires feel better now they;ve worn a bit. i think my biggest issue was to much throttle comming out of a turn before the car straightened out. as everyone has already said.. practice is key.
as for the alignment, i've adjusted the steering trim on the transmitter and it lines up pretty well. thanks for the heads up though.
       Post #: 16
