sailing1
OK, USA Status: offline
Bird-of-Prey, You can get below 16 pretty easy. My Extra is built with mostly stock parts from Tom's hardware kit except as follows. DA 50 on Pitts muffler with tubes cut off to fit the cowl. (Stock DA muffler is lighter by a bit) 4" Esprit fiberglass spinner-very light weight and you can paint to match. This is a huge weight savings over a True turn. Carbon wing and elevator tubes. Titanium tail wheel TNT carbon gear with PSP titanium axles with Kavan light wheels No Wheel pants. Single 2800 LiIon on receiver and ignition with reg's and standard switches. 5955 on rudder, 5985's everywhere else except throttle -- standard digitial, can't remember which one. NO choke servo. No Pilot figure. With all of these changes my weight is somewhere between 15 1/2 to 15 3/4 lbs. Hope that helps.
