Scooterpilot
CA, USA Status: offline
Tom, THanks for the quick response, I appreciate it. My first gasser is the WH YAK and I learned a lot assemblying the YAK. Since this is my second gasser, I'm really going to take a long time to assemble and and while doing so, I'm looking to reduce weight as much as possbile. I would prefer to buy carbon landing gear due to the weight savings. It sounds like the nylon gear is about the same weight as the metal gear. I was hoping to save 4 or more ounces on the gear. Next is the wing tubes and whatever else I can can do to reduce weight. If you have any other recommendations for weight reduction, please let me know. Regards Chuck
_____________________________
Scooterpilot Magnum Fuel
