RE: Newly redesigned WH Extra build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Newly redesigned WH Extra build thread
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Newly redesigned WH Extra build thread - 7/10/2006 4:43:31 PM
Dangerous Dan
Status: offline
Sharp exacto knife. Stick the knife tip in and cut by pulling on the spline. it will rotate a little but that is ok. To secure in place just drip a little thin CA around the inside.
_____________________________
when inverted down=up and up=$$
(in reply to bgold)
       Post #: 26
RE: Newly redesigned WH Extra build thread - 7/10/2006 8:18:09 PM
Scooterpilot
Status: offline
Hi,
I'm looking for a set of Carbon Fiber landing gear for the new Extra, any idea where I can get one?
Chuck
Scooterpilot
Magnum Fuel
(in reply to Dangerous Dan)
       Post #: 27
RE: Newly redesigned WH Extra build thread - 7/10/2006 9:33:48 PM
rctom
Status: offline
quote:
ORIGINAL: Scooterpilot
Hi,
Chuck
Actually we are selling a glass filled nylon gear that is super rugged. The only thing is it is straight legged gear so the looks change a bit, but it's very functional.
You will need to drill it and paint it yourself. $45 and I have them in stock. I'm not sure of the weight, I think it's about the same as the aluminum gear but it's much more durable.
TF
Click to see fullsize image.
Click for fullsize
(in reply to Scooterpilot)
       Post #: 28
RE: Newly redesigned WH Extra build thread - 7/11/2006 12:03:41 AM
Scooterpilot
Status: offline
Tom,
THanks for the quick response, I appreciate it.
My first gasser is the WH YAK and I learned a lot assemblying the YAK.
Since this is my second gasser, I'm really going to take a long time to assemble and and while doing so, I'm looking to reduce weight as much as possbile. I would prefer to buy carbon landing gear due to the weight savings. It sounds like the nylon gear is about the same weight as the metal gear. I was hoping to save 4 or more ounces on the gear. Next is the wing tubes and whatever else I can can do to reduce weight.
If you have any other recommendations for weight reduction, please let me know.
Regards
Chuck
Scooterpilot
Magnum Fuel
(in reply to rctom)
       Post #: 29
RE: Newly redesigned WH Extra build thread - 7/11/2006 12:42:08 AM
RCFREAK
Status: offline
Hey Mate, there are heaps of things you can do to make you plane lighter. Here are some ideas:
Carbon Wing Tube
Carbon Elevator Stab Tube
Carbon Fiber Main Landing Gear
Carbon Fiber Tail Wheel
Lightened backplate on the spinner / or get a carbon one
Li-Ion Batterys all around
Smaller tank, try a 20oz
Light weight wheels and axles help allot. Try Karvan Wheels with PSP Manufacturing Titanium Axles
I dont know if a CF Prop is lighter than a woody? help me out here guys. I know PT Carbon is light
Take out any unessacary items that are not needed inside the plane.
I have worked out , i can save anywhere inbetween 400-500 grams in my upcoming plane. Thats HALF A KG.
       Post #: 30
RE: Newly redesigned WH Extra build thread - 7/11/2006 1:12:27 AM
Scooterpilot
Status: offline
RCFREAK,
Thanks for the information.
I've ordered Karvan Wheels with PSP Manufacturing Titanium Axles
Li-Ion Batterys
Carbon spinner and lighten backplate
Wooden Prop
I've been looking at Carbon-titanium pushrods.
Regards,
Chuck
Scooterpilot
Magnum Fuel
(in reply to RCFREAK)
       Post #: 31
RE: Newly redesigned WH Extra build thread - 7/11/2006 3:15:35 AM
Dangerous Dan
Status: offline
fly with the aluminum gear and save some $$ I had CF gear on ny extra special and 260, No matter how gentle you land it will eventually delaminate..I switched back to aluminum gear and could not tell the difference
       Post #: 32
RE: Newly redesigned WH Extra build thread - 7/11/2006 3:35:14 AM
airborneSGT
Status: offline
Just a thought but if I wanted to be really really light I would get the Yak...lol. You can easily spend a lot to save weight on a plane. There comes a point when you realize its not worth it. With this thing around 16lbs with a DA 50 I think it is plenty light. I think the farthest I would go would be a wing tube not so much for the light factor but for strength. Kavan's are another cool way to save weight but they sure do get eaten up fast if you fly on a paved runway.
Again I think at an honest 16lbs with no mods this thing is going to be amazing. The newer designs rival that of some of the most trick custom built kits. Lotsa lightening holes and yet re-enforcement where you need it.
       Post #: 33
RE: Newly redesigned WH Extra build thread - 7/11/2006 3:41:33 AM
Greg Cothern
Status: offline
Since were on a weight savings plan let me ask this question then. Would a Lithium Ion 7.4v pack that is built with 18 awg leads and Deans connectors to a power expander power 5 flight surfaces on digitals (rudder on a 5995 tg pull pull)? Use a Lion on regulator for the ignition as well.
This would drop your weight down as well as simplify setup, would not have to have but 1 pack, one regulator, power expander has a switch already. Thoughts????
If this would work then I think one could keep the weight under 16 fairly easily.
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
(in reply to airborneSGT)
       Post #: 34
RE: Newly redesigned WH Extra build thread - 7/11/2006 3:54:53 AM
Dangerous Dan
Status: offline
quote:
ORIGINAL: Greg Cothern
NO in extreme manuevers your voltage would drop from the regulator a second pack regulator and switch is 4oz more, but it i functional weight. at 16 pounds stock this plane will be a rocked. I spent $300 on CF items for my 260 and it i had it to do over I would have kept everything stock except the wing tube!
(in reply to Greg Cothern)
       Post #: 35
RE: Newly redesigned WH Extra build thread - 7/11/2006 3:58:26 AM
Dangerous Dan
Status: offline
NO in extreme manuevers your voltage would drop from the regulator a second pack regulator and switch is 4oz more, but it i functional weight. at 16 pounds stock this plane will be a rocket. I spent $300 on CF items for my 260 and it i had it to do over I would have kept everything stock except the wing tube! Use CF to make a heavy plane light. If you already have a light plane don't waste your money. Build it stock and fly it. Then deside if its worth all the $$$ to make it even lighter.
       Post #: 36
RE: Newly redesigned WH Extra build thread - 7/11/2006 4:20:37 AM
airborneSGT
Status: offline
Spoken like a true pro. I guess I shouldnt talk though, I spent a bunch of money to have my plane pimped out by Tony. Well it will sure look nice though.
I would think one 4 cell lion would be fine for hard 3D. I only say this as I have flown dozens of flights on 28% planes using one 4 Cell lion pack and 6 digi servos with no problems. I am talking about from take off until landing nothing but rollers, walls, slow knife edge flight. Oh yeah that was also with no power expander and a really small PCM RX.
If you wanna save weight with the ignition setup get that trick built in reg switch from Duralite. I just wonder if it will put a load on the battery when off.
       Post #: 37
RE: Newly redesigned WH Extra build thread - 7/11/2006 5:20:11 AM
Greg Cothern
Status: offline
AirborneSGT, so how many flights with 1 - 4 cell Lion pack could you get in a day? I completely understand the benefits of a second redundant pack etc, just would like to simplify things if it will work correctly.
I was looking at the new Smart-Fly ignition regulator, it is pretty small and effective.
       Post #: 38
RE: Newly redesigned WH Extra build thread - 7/11/2006 5:28:09 AM
