RE: Newly redesigned WH Extra build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Newly redesigned WH Extra build thread
Page: <<   < prev  13 14 15 16 17 18 19 20 21 [22]
Login
RE: Newly redesigned WH Extra bui... - 7/17/2007 2:40:06 PM
rctom
Status: offline
Is the harrier with power on? If so I'd say yes, more thrust may help but it will affect the rest of the flight envelope. I'd just use more rudder if everything else is pretty close.
TF
(in reply to Greg Cothern)
       Post #: 526
RE: Newly redesigned WH Extra bui... - 7/17/2007 2:42:07 PM
Greg Cothern
Status: offline
Tom, the harriers would be on a low power setting, if I add much power she pops up into a hover... I have been flying the rudder in harriers but was curious.
_____________________________
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
(in reply to rctom)
       Post #: 527
RE: Newly redesigned WH Extra bui... - 7/17/2007 2:47:11 PM
Dangerous Dan
Status: offline
Did you Laterial Balence?
From a high altitude drop to idle and push straight down, Then pull to level pull until the plane is just horozontal not hard enough to snap though the wing needs to keep flying.
Check to see if a wing drops, Repear 10 times, If the same wing ALWAYS drops add a little weight to the opposite wing. Make sure you are only applying levator in the pull.
when inverted down=up and up=$$
       Post #: 528
RE: Newly redesigned WH Extra bui... - 7/17/2007 4:09:28 PM
Tired Old Man
Status: offline
With all the planes I've done harriers and waterfalls with I've found the need to lead the maneuver with rudder to counteract torque and what's known as "spiral slipstream". As the plane comes up the back of a waterfall is where the most rudder is needed. Harriers are about the same for me an require about the same about of rudder all the way through unless it's one where changing directions come into play. Then the rudder is used for the majority of the steering. Using the ailerons for steering causes a wing to drop pretty quick unless elevator and rudder is used to hold them up. Perhaps I'm a bit on the lazy side but I never even check lateral balance anymore unless there's a severe problem that I can't find another answer for.
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to Dangerous Dan)
       Post #: 529
RE: Newly redesigned WH Extra bui... - 7/29/2007 11:58:42 AM
Tetley
Status: offline
Hi, Can one of you guys tell me where the cg ends up if you measure near the fuzz not the wingtips??
I Just got my fromeco kit and want to set it out to achieve the cg. Right now Its sitting about the middle of the wing tube Just behind the black covering underneath.
Cheers dudes!
Jim.
(in reply to Tired Old Man)
       Post #: 530
RE: Newly redesigned WH Extra bui... - 7/29/2007 7:49:55 PM
mstroh3961
Status: offline
Put the wings on the tube and stretch a string across and mark it.
Regards
Mark
(in reply to Tetley)
       Post #: 531
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU4
