RE: Newly redesigned WH Extra build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Newly redesigned WH Extra build thread Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Newly redesigned WH Extra build thread - 7/18/2006 2:11:36 AM
Greg Cothern
Status: offline
I decided to go with a 4 cell 7.4V 4400MaH Lithium Ion pack with 16AWG lead and Deans connector from Super Battery Packs.
Click to see fullsize image.
Click for fullsize
_____________________________
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
(in reply to Greg Cothern)
       Post #: 51
RE: Newly redesigned WH Extra build thread - 7/18/2006 3:06:19 AM
Redneck Shaun
Status: offline
Man ....That's a hoss!!!! I ended up using three Fromeco 7.4v 2400MAH. The only thing is it looks like my CG is going to be a tad forward then I thought it would be. I ended building a tray with the extra spare wood.I mounted it aft the pull-pull rudder servo to hold two of the batteries. The other battery I will mount just forward of the rudder servo.
In all honesty, I probably could install the rudder servo in the tail and get a lot closer to the wanted cg range.
Here's a couple picture of the tray I built tonight.
Click for fullsize
Click for fullsize
Fellowship of Christian Modelers
www.fcmodelers.com
       Post #: 52
RE: Newly redesigned WH Extra build thread - 7/18/2006 3:09:21 AM
Redneck Shaun
Status: offline
Here's the radio position, and the tail area. I'm almost ashamed to show the pictures before I have a chance to clean up the wiring.
Click for fullsize
Click for fullsize
www.fcmodelers.com
(in reply to Redneck Shaun)
       Post #: 53
RE: Newly redesigned WH Extra build thread - 7/18/2006 4:52:36 AM
Greg Cothern
Status: offline
I was looking for a setup that was simple yet effective, I think this should be enough power running through a HD adjustable Smart-Fly regulator and HD switch, all of which should if fail do so in the on position. Well all but the battery LoL.
I plan to run a 2 cell LI-ion on ignition.
       Post #: 54
RE: Newly redesigned WH Extra build thread - 7/20/2006 5:31:03 AM
Greg Cothern
Status: offline
Got all the hinges gorilla glued in yesterday evening, cleaned them up this evening. Sure is less hassle and messy versus epoxy. I do cheat a little and use vaseline or such to coat the hinge points and covering anywhere I think it might foam out. Works great!
       Post #: 55
RE: Newly redesigned WH Extra build thread - 7/20/2006 5:45:41 AM
Dangerous Dan
Status: offline
Greg,
I have a little metal cup. I think it was a votive candle mold(shhh don't tell the wife). I fill this with vasoline and place on my monocoat iron. The iron is proped up horozontal and inverted. I dip the knuckle of the hinge in, then bend the hinge the other way and stick it in again. The excess vasoline is wiped away with acetone, so it does not prevent the glue from doing its job. By liquifing the vasoline you get it down inside the movable part of the hinge and away from the glue surfaces.
Dan P
< Message edited by dntmn -- 7/20/2006 2:10:00 PM >
when inverted down=up and up=$$
       Post #: 56
RE: Newly redesigned WH Extra build thread - 7/20/2006 9:56:43 AM
Greg Cothern
Status: offline
Thanks for the tip!
(in reply to Dangerous Dan)
       Post #: 57
RE: Newly redesigned WH Extra build thread - 7/20/2006 2:55:30 PM
rctom
Status: offline
It is my experience that I am FAR more likely to get vaseline on the shaft of the hinge (thus ruining the glue joint) than I am to get glue in the knuckle of the hinge. I have never used a lubricant and never had a problem.
I discourage use of any oil until all the glue is dried, then you can put a drop on the hinge knuckle. YMMV.
TF
       Post #: 58
RE: Newly redesigned WH Extra build thread - 7/20/2006 4:11:31 PM
Greg Cothern
Status: offline
Tom when I built the WH Edge I had problems with the gorilla glue foaming out and getting in the hinge knuckle and making them very stiff. Had to work with an exacto for a while to dig out the glue LoL, so this time I wanted to make sure I did not have this problem.
I made very certain that I cleaned off the hinge shaft with denatured alcohol prior to glue application. I give my control surfaces a BIG pull after assembly and trust me these puppies are not going anywhere that it doesnt take half the wood in the wing with them LoL.
I do echo your concern for having a clean glue surface though, one must take precautions to keep the glue surface absolutely clean and lubricant free.
(in reply to rctom)
       Post #: 59
RE: Newly redesigned WH Extra build thread - 7/20/2006 4:27:21 PM
Dangerous Dan
Status: offline
I use an abrasive cloth and acetone to clean the shaft. I glue into the "plane side" first, for this side I baby sit and wipe the glue as it oozes. When the control surface is attached I use blue painters tape to hold the surface to the plane and pick off the hardned glue the next morning. I have close two 500 flights between my 2 wildhares and have never had a hinge issue. I have done Tom's method, but it is a little harder to clean the glue out, it works equally as well.
       Post #: 60
RE: Newly redesigned WH Extra build thread - 7/21/2006 3:34:03 AM
airborneSGT
Status: offline
With the GG did yall do as Tom suggested and tape over the hinge hole and then just cut a small hole in the tape? This prevents mess getting on the plane and keeps most of the hinge.
I think the other stuff I might now use beside the GG is Hysol although for the app. I think GG has the edge as it expands while drying.
       Post #: 61
RE: Newly redesigned WH Extra build thread - 7/21/2006 3:42:11 AM
Dangerous Dan
Status: offline
I use the blue tape but before gluing the surface to the plane ai carefully cut the tape along the hing line, otherwise it is a real pain to remove.
(in reply to airborneSGT)
       Post #: 62
RE: Newly redesigned WH Extra build thread - 7/21/2006 11:31:07 AM
Redneck Shaun
Status: offline
Yea, That's what I did. It does a great job keeping it off the plane. However with the expanding GG, there is still clean up to do with the x-acto knife. It might have to do with the amount of glue but in to the hole too. I would rather know that I have a good joint and have a little more clean up.
Shaun
www.fcmodelers.com
       Post #: 63
RE: Newly redesigned WH Extra build thread - 7/21/2006 1:51:22 PM
airborneSGT
Status: offline
Thats the only watching of the plane part while the hinges dry with the GG glue. For getting them lubricated from the get go I use 3 in 1 oil. Even if a little GG gets out its nothing a hobby knife wont fix. Done this with a bunch of planes and never had a problem. I usually end up sealing both sides of the hinge gaps so you wont even see the hinge knuckles.
Those lion's with the pimp wire and
