RE: Newly redesigned WH Extra build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Newly redesigned WH Extra build thread
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Newly redesigned WH Extra build thread - 7/25/2006 4:06:59 AM
Greg Cothern
Status: offline
Here are a couple more PICs, one of the canopy with screws holding in place, took Toms advice on cutting down the muffler to just clear the ring and it worked great. As always Tom give great advice!!!!
Click to see fullsize image.
Click for fullsize
_____________________________
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
(in reply to texomalaser)
       Post #: 76
RE: Newly redesigned WH Extra build thread - 7/25/2006 4:08:58 AM
Greg Cothern
Status: offline
Another
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Greg Cothern)
       Post #: 77
RE: Newly redesigned WH Extra build thread - 7/25/2006 4:16:00 AM
Scooterpilot
Status: offline
Greg,
How much did you cut off the exhaust?
Scooterpilot
Magnum Fuel
       Post #: 78
RE: Newly redesigned WH Extra build thread - 7/25/2006 5:35:31 AM
rctom
Status: offline
Put something around the plug wire to protect it, that fiberglass edge will saw through it in 1 or 2 flights the way it is.
TF
(in reply to Scooterpilot)
       Post #: 79
RE: Newly redesigned WH Extra build thread - 7/25/2006 6:21:52 AM
SKYPILOT
Status: offline
With respect to post 69,
Thanks Tom, i was afraid of that, not set on an airframe yet, if i go with your line, i'll stick with the Cap then. My engine choice is set with the 3W-56b2, but i need/want it to be fully inclosed. Getting closer to a decision now
Regards, Scott
(in reply to rctom)
       Post #: 80
RE: Newly redesigned WH Extra build thread - 7/25/2006 6:59:03 AM
Greg Cothern
Status: offline
Tom, absolutely will, the PIC was just a mock up and the muffler is not even bolted on, nor is the cowl LoL. I always protect the plug wire, thanks for the tip though it is always good to alert of such information. Thanks.
(in reply to rctom)
       Post #: 81
RE: Newly redesigned WH Extra build thread - 7/25/2006 7:10:22 AM
Greg Cothern
Status: offline
Scooterpilot, ya know I didnt measure how much I cut off, I did more measuring of how much clearance I needed to pass the cowl ring. I had to extend my cowl opening to go just behind the exhaust tubes, did this by using construction paper/card stock to make a template. Then transferred that onto my cowl and cut just shy of my measurements, I like to sneak up on it LoL. Then I measured down from the engine box to the top of the cowl ring and used that to make a guess-ta-mate. I then cut the exhaust tubes and mocked it up and just needed to trim about a 1/8th of an inch more and thats what you see now. I can measure the tubes from the muffler body to the end and post that measurement if you need??? Let me know.
       Post #: 82
RE: Newly redesigned WH Extra build thread - 7/25/2006 2:08:59 PM
Greg Cothern
Status: offline
Measured the exhaust tubes and they are 55mm long from the main body of the muffler to the tips.
       Post #: 83
RE: Newly redesigned WH Extra build thread - 7/25/2006 2:52:23 PM
danielwidman79
Status: offline
I like to se more photos of this plane on your webbsite. It would be lovley to se a DA 50 with canister!
       Post #: 84
RE: Newly redesigned WH Extra build thread - 7/25/2006 4:09:08 PM
rctom
Status: offline
Yes, wouldn't it. I'd happily do this if I had a plane. All I have is the prototype which did not have the canister tunnel built in.
Maybe in the next group I can allocate one for a build, or maybe someone out there is doing this.
TF
(in reply to danielwidman79)
       Post #: 85
RE: Newly redesigned WH Extra build thread - 7/25/2006 4:32:41 PM
Scooterpilot
Status: offline
Greg,
Thanks for taking the time to explain how you mounted the cowl and the exhaust lenghts.
Chuck
AKA Scooterpilot
< Message edited by Scooterpilot -- 7/25/2006 6:45:05 PM >
Scooterpilot
Magnum Fuel
(in reply to rctom)
       Post #: 86
RE: Newly redesigned WH Extra build thread - 7/25/2006 6:23:43 PM
flyingohio
Status: offline
I plan on building mine with a canister muffler, I think both the stock DA muffler and pitts are too loud. (for my tastes) Do you sell cans Tom? If so I will call you and "upgrade" my order. When's the container coming... I'm anxious!
       Post #: 87
RE: Newly redesigned WH Extra build thread - 7/26/2006 4:56:43 AM
rctom
Status: offline
quote:
ORIGINAL: flyingohio
Me too! Yes we have a canister kit for the DA-50 which includes the header, muffler, all mall parts. $219.
Container is still on a train.
TF
(in reply to flyingohio)
       Post #: 88
RE: Newly redesigned WH Extra build thread - 7/30/2006 8:58:42 PM
Redneck Shaun
Status: offline
Well mine is getting close!! All I have left to do is seal the surfaces, and check the lateral balance. Looks like it will be sometime this week for the maiden. The pictures don't do the plane just. She's a real looker!!!!
Greg thanks for the advise on the canopy. she came out looking great.
Shaun
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fellowship of Christian Modelers
www.fcmodelers.com
(in reply to rctom)
       Post #: 89
RE: Newly redesigned WH Extra build thread - 7/30/2006 9:03:29 PM
Scooterpilot
Status: offline
Redneck Shaun,
That is one nice looking plane. I can't wait to hear how it flies.
I won't be able to start on mine until Thanksgiving :-(
Regards
Chuck
Scooterpilot
Magnum Fuel
(in reply to Redneck Shaun)
       Post #: 90
RE: Newly redesigned WH Extra build thread - 7/30/2006 9:04:50 PM
Greg Cothern
Status: offline
Shaun, looks great! I will not be able to maiden mine for probably for about 10 more days, due to work and a camping trip, arrrrg.
