Tired Old Man
CA, USA Status: offline
Looking at the pictures of the bottom of the cowl in post #77, I have some concerns about engine cooling. There's not much head hanging out the bottom of this one and the cowl is cut tight to the exhaust. I know that it was noted that everything is not mounted up yet, but don't forget that 3 or 4 to 1 cooling air to hot air exit area ratio. Not enough hot air exit area is a very fast way to cook an engine. That or the engine will always be sagging after a few minutes of flight and you'll be banging your head against the wall trying to figure what's wrong with the engine. Once that spinner back plate goes on there's not much intake area left over, and the biggest part of that is cut of from moving air by the prop arc itself. Keep cooling in mind folks.
_____________________________
If you can''t fix it with a hammer, you have an electrical problem.
