RE: Newly redesigned WH Extra build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Newly redesigned WH Extra build thread
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Newly redesigned WH Extra build thread - 8/14/2006 3:50:56 AM
marzo91
Status: offline
I just finished up my new Extra this evening. It'll be powered by a Brison 3.2 with a pitts style muffler. I used the hardware from Tom's hardware kit. I have a carbon fiber wing tube. I use a Li-ion 2800 for the ignition and one for the receiver. No choke servo, no pants, no cuffs, and no spinner. That's the way I fly them. It may be stripped down a bit, but it only weighs 15 pounds, 11 ounces.
(in reply to dhooks)
       Post #: 151
RE: Newly redesigned WH Extra build thread - 8/14/2006 3:54:54 AM
JimRoss
Status: offline
Anybody need a set of wings and tail feathers for a 28% Extra 300 Special? I just happen to have a set, cheap
_____________________________
No matter where you go, there you are.
Of All the people I know, you're one of them.
(in reply to rctom)
       Post #: 152
RE: Newly redesigned WH Extra build thread - 8/14/2006 4:03:06 AM
Dangerous Dan
Status: offline
http://whiteknuckleairlines.com/index.php?option=com_zoom&Itemid=26&page=view&catid=10&PageNo=1&key=3&hit=1
when inverted down=up and up=$$
(in reply to JimRoss)
       Post #: 153
RE: Newly redesigned WH Extra build thread - 8/14/2006 3:17:10 PM
Greg Cothern
Status: offline
Looks good Shaun!! I have hit a snag (personal nothing to do with the bird) that has put my bird a bit off from being finished this week. But hopefully will have it in 2.
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
(in reply to Dangerous Dan)
       Post #: 154
RE: Newly redesigned WH Extra build thread - 8/15/2006 3:34:07 AM
JimRoss
Status: offline
Wings and stabe are SOLD pending funds. Thanks guys for the interest.
(in reply to Greg Cothern)
       Post #: 155
RE: Newly redesigned WH Extra build thread - 8/15/2006 3:39:27 AM
Redneck Shaun
Status: offline
Thanks Greg. Life sometimes life seems to throw a curve ball from time to time. I'll make the time you have to wait worst though, by saying this plane is really better then I expected!!!! Come up to our field sometime and I'll let you fly mine while your getting your together.
Shaun
Fellowship of Christian Modelers
www.fcmodelers.com
       Post #: 156
RE: Newly redesigned WH Extra build thread - 8/23/2006 2:54:26 AM
Greg Cothern
Status: offline
Few more PICs of the interior setup. Single Futabe PCM receiver, 7.4V 2 cell Lithium Ion 4800 Mah pack (16awg lead with Deans), Smart-Fly adjustable Heavy Duty regulator (also equipped with Deans), Smart-Fly Super DSC switch with 18ga input, dual 22ga outputs.
Dubro 24 oz tank, fueler inside under canopy hatch, I did not want to cut another hole in the side of the fuse and always a good idea to do a good check between flights right?!!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Greg Cothern -- 8/23/2006 3:26:21 AM >
(in reply to Redneck Shaun)
       Post #: 157
RE: Newly redesigned WH Extra build thread - 8/25/2006 12:54:22 AM
Redneck Shaun
Status: offline
Looking good Greg.But I bet your going to get real tired of taking off that canopy to fill her up though. What about underneeth where it doesn't show?
Oh are you going to be able to visit our IMAC coming up a week from this Saturday?
www.fcmodelers.com
       Post #: 158
RE: Newly redesigned WH Extra build thread - 8/25/2006 1:00:46 AM
Greg Cothern
Status: offline
Shaun I thought about having to remove the canopy, just couldnt put another hole in this gorgeous bird LoL. Not a problem at all for me to removed the canopy to refuel, I usually like to take a peak inside every couple flights anyway LoL. If it becomes a pain I can easily put the fueler in normally through the side or out the bottom or such.
Dont know if I can make up or not, will have to see, shoot me an email off forum with the details, I will see what I can do might be a good excuse to get in a motorcycle ride LoL.
       Post #: 159
RE: Newly redesigned WH Extra build thread - 8/25/2006 3:51:30 AM
rcfury
Status: offline
Maybe putting on a hatch latch from BVM could help elleviate the hassle on taking on and off the hatch. Ive put one on my showtime 4d and gosh no more loosing screws, and i can get into the hatch within a click.
Nathan
AMA# 794162 + R/C combat association (RCCA #788)
       Post #: 160
RE: Newly redesigned WH Extra build thread - 9/2/2006 4:00:37 PM
Greg Cothern
Status: offline
Since I have been waiting on some funds to get the last couple items needed to finish my Extra, I decided against the fueler being inside under the canopy hatch. Put it out the bottom.
Hope to have it finished later today, but alas it hasnt rain but 3 times all summer and now they are calling for rain LoL.
Will post completed weight later.
(in reply to rcfury)
       Post #: 161
RE: Newly redesigned WH Extra build thread - 9/2/2006 4:06:36 PM
JimRoss
Status: offline
Greg, what did you do about getting to the carb mixture screws? I'm about to go drill two holes in my cowl for access to the screws.
       Post #: 162
RE: Newly redesigned WH Extra build thread - 9/2/2006 5:13:33 PM
Greg Cothern
Status: offline
Jim, I actually was not going to drill the cowl, I usually run the engine and set the needles on the ground with the cowling off then install before flight.
I have in the past drilled the cowl, but always seemed like I could never hit the adjusting screws, LoL, so I ended up pulling the cowling anyway.
       Post #: 163
RE: Newly redesigned WH Extra build thread - 9/2/2006 5:58:02 PM
flatlandmike
Status: offline
FYI a single small hole the size of a screw driver will work for both screws on the da50.
www.jerseymodeler.com
Special thanx to The Crew Mike B. Jim Z. Ed J. Jim S.
       Post #: 164
RE: Newly redesigned WH Extra build thread - 9/2/2006 5:59:29 PM
Greg Cothern
Status: offline
FLatlandmike, same for the MVVS or Evolutions.
(in reply to flatlandmike)
       Post #: 165
RE: Newly redesigned WH Extra build thread - 9/3/2006 12:32:43 AM
Greg Cothern
Status: offline
I have a final weight, finally, LoL . A few ounces more than I tried for but she came in at 16 lbs 8 oz's. I used all stock parts with the exception of tail wheel, I used a CF unit just because I already had it.
Here are the weights of each component.
Fuse (bare fuse minus canopy, hatch, cowl, stab, etc) 2 lbs 14.6 oz's
Hatch (without canopy) 7.4 oz's
Canopy 9.2 oz's Not sure if all the others have as heavy of a Canopy as mine, should be quite sturdy though hehehe.
Cowl 9.2 oz's
Landing gear (without axles etc) 9.4 oz's
Wheel Pants (bare) 2.6 oz's
Right wing panel 1 lb 2.2 oz's
Left wing panel 1 lb 2.2 oz's
Right elevator/stab 4.7 oz's
Left elevator/stab 4.2 oz's
Rudder 3.4 oz's
Wing tube 9 oz's
Stab tube 1.2 oz's
Tail Wheel assembly w/hardware 2.8 oz's
Misc
