73" Yak Servo Size?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> 73" Yak Servo Size?
Page: [1]
Login
73" Yak Servo Size? - 7/8/2006 5:38:37 AM
Gimble Bender
Status: offline
Reza,
What size servos are required for the 73" Yak? (oz/in) I tried downloading the manual but can't get it to work on my pc. I have some Futaba 3010's that just came out of my newly re-kitted Jerry's Big Boy and wanted to know if they were enough.
Specs..
4.8V 72.2 oz-in. 0.20 sec/60°
6.0V 90.2 oz-in. 0.16 sec/60°
I run Fromeco Li-Ion batterys and regulators at 6 volts.
I also have a Futaba 9151 digital to use on the rudder.
4.8V 131.9 oz-in. 0.19 sec/60°
GB
_____________________________
Built for go, not for show.
       Post #: 1
RE: 73" Yak Servo Size? - 7/8/2006 5:41:59 AM
Rezagh
Status: offline
Hi GB,
Rudder is OK but others are not strong enough. Don't use those servos. Get at least 130 oz and DIGITAL!
Thank you,
Reza
Quique's Aircraft Company
(in reply to Gimble Bender)
       Post #: 2
RE: 73" Yak Servo Size? - 7/8/2006 6:52:44 AM
Gimble Bender
Status: offline
Thanks Reza,
Thats what I thought anyway, but wanted to make sure. I think i'm going to let Randy (randy racer) be the guinee (Sp???) pig for this one since he's putting a 3W 28 in his. My JBB had a 3W-24 that i'm trying to get broken-in. (It flamed out on me at a bad time, resulting in the re-kitting of the airframe.) If all works out well and he likes it, I will probably do the same. I'll also install JR 8611a servos on all surfaces. The futaba servos I have were allready in that big boy when I got it.
Thanks again Reza,
GB
(in reply to Rezagh)
       Post #: 3
RE: 73" Yak Servo Size? - 7/8/2006 8:02:45 AM
Rezagh
Status: offline
Anytime GB. Yeah, have Randy do it first
Keep me posted.
Reza
       Post #: 4
RE: 73" Yak Servo Size? - 7/8/2006 12:07:33 PM
randy racer
Status: offline
i hope to have the 73 ready to fly in a week or so. after building 2 102"s in the last 5 weeks i need a couple of days away from the build table and some time at the airfield. i will keep you posted.
GB, it's about time you stepped up to a QQ yak. go ahead and get the 73" on the way we will figure out what engine to use.
randy racer
Revver Bro #196
Ford RV Refrigeration Training Center & The RVRN
       Post #: 5
RE: 73" Yak Servo Size? - 7/8/2006 2:03:48 PM
ramduster
Status: offline
Will the Jr sport 125 Mg or hitec 645 Mg work because that is all I have at this time.
(in reply to randy racer)
       Post #: 6
RE: 73" Yak Servo Size? - 7/8/2006 3:46:36 PM
randy racer
Status: offline
what are the specs on those servos? always use the best servos you can afford, it's like putting $$ in the bank. the plane will fly better and longer, and when it's time for a rekit you will have good servos to put in the nest and bigger QQ yak.
randy racer
Revver Bro #196
(in reply to ramduster)
       Post #: 7
RE: 73" Yak Servo Size? - 7/8/2006 6:18:09 PM
ramduster
Status: offline
HS-645MG
107 4.8V
133 6.0V
.24 sec.
.20 sec.
JR Type: Standard Hi Torque Metal Gear
Torque: 125 oz/in @ 4.8V
Speed: .21/60 @ 4.8v, .17/60 @ 6v
Dimensions: 0.73 x 1.55 x 1.46
Weight: 1.60 oz
Application: 120 size Aircraft
not sure what the torque is at 6.0 volts on the JR but should be about the same as hitec.
       Post #: 8
RE: 73" Yak Servo Size? - 7/9/2006 2:51:57 AM
randy racer
Status: offline
that should work. good luck with the build.
randy racer
Revver Bro #196
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU5
