Problem with 5735
Tower Hobbies
Logged in as Guest
  Printable Version
202oz Servo With Money Back Guarantee
Seller:  monstertruck2000
Details:   $17.95   |  1/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Problem with 5735
Page: [1]
Login
Problem with 5735 - 12/30/2002 10:34:42 AM
fdo300
Status: offline
Hi Mike
I just received the Hitec servos for my next proyect and I have a problem with the 5735's
When I connect the servos to a Y- harness one of them start to acting erratically, I mean, if I move the radio stick really slow both servos move correctly, but when I move the stick a little faster one servo work ok and the other ( allways the same one) doesn't move until 4-5 second after the other. If I disconnect the "good" servo from the Y-Harness the "bad" one work ok,
I'm using futaba PCM receiver and Radio
Both servos have a sticker that say may02 !!!
What can I do ???
Fernando
< Message edited by fdo300 -- Dec 30 2002 10:34PM >
       Post #: 1
Problem with 5735 - 12/30/2002 10:51:06 PM
MikeMayberry
Status: offline
It sounds like the power bus in the receiver is limiting the current. What you will need to do is power the servos directly. Add another y-harness to the reciever and then plug the other y-harness with the two servos into one end and the battery into the other. Make sure you are using heavy duty harnesses.
Mike.
(in reply to fdo300)
       Post #: 2
Problem with 5735 - 12/31/2002 1:42:07 AM
fdo300
Status: offline
Mike
I did the same test with two 5945 and they work perfect, personally I think it a problem with the servo because the other 5735 work ok connected to any of the Y-harness terminal.
I forgot to tell you that the servor are not connected to the rudder so they pull any load.
regards
Fernando
       Post #: 3
Problem with 5735 - 12/31/2002 3:32:36 AM
MikeMayberry
Status: offline
Send it in and we will look at it.
Mike.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU5
