rudder systems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> rudder systems
Page: [1]
Login
rudder systems - 7/9/2006 5:54:15 AM
husafreak
Status: offline
I am considering one of the high tech rudder systems for my 102" YAK. There is the Airwild system with aluminum tray for two Futaba 9152's and the even more impressive SWB system. They are both available with straight or offset rudder tillers, The SWB comes in 4", 4 1/4", and 4 1/2" offset arms, the Airwild in a 5" only. Can these be used with my Yak? Thanks, Eric
       Post #: 1
RE: rudder systems - 7/9/2006 6:49:57 AM
Rezagh
Status: offline
Eric,
Yes, the SWB can be used(I think 4" with 7 degree offset and pull-pull goes straight instead of cross), but why do you need to do that? Use the CF arm and mount your servos in the space provided. Manual is coming this week.
Reza
_____________________________
Quique's Aircraft Company
(in reply to husafreak)
       Post #: 2
RE: rudder systems - 7/9/2006 11:52:47 AM
randy racer
Status: offline
i used the SWB self adjusting on my first 102 and it's a sweet set up. on the 2nd one i set it up stock and went from two 4800's on the reciever to two 2400's and saved a little over a pound. a pound is a ton on a 102" airplane, it flys great at 27.5lbs but at a little under 26.5 it's awsome!!!! it work both ways so do what make you feel better.
randy racer
Revver Bro #196
Ford RV Refrigeration Training Center & The RVRN
(in reply to Rezagh)
       Post #: 3
RE: rudder systems - 7/9/2006 10:48:25 PM
husafreak
Status: offline
Thanks guys, saving weight is a big deal to me, but the idea of loading Futaba servo bearings and rabbit ear arm extensions with the pull/pull cable tension makes me cringe. I don't want to do it. I was very interested to read that you had the SWB setup and decided not to use it your second time, I think I'll skip the first step! The YAK has such a nice tray allready built in... I think I know what to do now, I'll use the standalone BB supported tiller kit and modify it with FRP plates cut to the plan dimensions, add the least amount of weight, unload my servo, use as much of the kit as I can. Oh, by the way, how long can you fly on 2400 mAh? Eric
(in reply to randy racer)
       Post #: 4
RE: rudder systems - 7/10/2006 1:17:30 AM
randy racer
Status: offline
i am using 3 Fromeco 2400's with regulators, 1 ignition and 2 on reciever. i can fly around 10 twelve min flights. if i were going to use just one reciever battery i would use a 4800, but i feel better with a 2nd battery just in case of a battery, switch, or regulator problem.
randy racer
Revver Bro #196
       Post #: 5
RE: rudder systems - 7/10/2006 8:15:00 PM
husafreak
Status: offline
That sounds great, thanks. Eric
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU4
