RE: .50 size electric trex 600!!!
Tower Hobbies
Logged in as Guest
  Printable Version
HELICOPTER PROBLEMS OR NO EXPERIENCE: LET OUR STANDS AID YOU - RTR
Seller:  helisafestuff
Details:   $99.95   |  1/3/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> RE: .50 size electric trex 600!!!
Page: <<   < prev  1 [2]
Login
RE: .50 size electric trex 600!!! - 7/22/2006 12:43:02 AM
choppersrule
Status: offline
Credence,
Sounds like you are as happy as a kid in a candy store. Don't blame you one bit.
Just make sure that you make the payments on time.
Keep us posted and send pics and videos when you can. We are all behind you, isn't this hobby just great!
Best to you,
Dave / Choppersrule
_____________________________
Left skid low....
(in reply to credence)
       Post #: 26
RE: .50 size electric trex 600!!! - 7/22/2006 10:57:49 AM
cptsnoopy
Status: offline
I should have taken some pics! My brothers trex-600 showed up yesterday and between then and now, approx 8 hours have been spent on it's assembly. It is all together with the exception of installing the servo's and the links from the servos to the arms to the swash. The head from swash up is done. The other items to be installed are the esc, gyro, bec and receiver. Mostly just the radio stuff. It really looks to be a quality kit. I have not had any of the issues that I have read about others having. The only problem that I noted during assembly of the tail was the threads on the ball that goes into the tail slider were too long and they jammed the tail slider bushing. I had to file the threaded portion shorter and it seems ok now. It may or may not get finished tomorrow but we can only hope.
(in reply to choppersrule)
       Post #: 27
RE: .50 size electric trex 600!!! - 7/22/2006 11:35:18 AM
credence
Status: offline
How are the linkages? Any slop? My only concern is with the plastic torque levers that i've seen for the aileron servos. I'm wondering if this is one of the "high stress" areas that was addressed in the factory revisions or not. I know alot of guys have been replacing them with the metal versions right off the bat.
Daniel
True Northern Hobbies, Inc.
(in reply to cptsnoopy)
       Post #: 28
RE: .50 size electric trex 600!!! - 7/22/2006 10:11:14 PM
cptsnoopy
Status: offline
The links seemed fine. No cracking yet, not all installed though. I think your refering to the links that ride on bearings and are mounted on a small shaft just behind the main shaft? two push-pull links from the servos to one link from the arm up to the swash? These parts all seemed plenty beefy to me. I had no concern after installing them that they might flex or break unless in a crash. Some folks have said that theirs had slop from side to side, the kit that my brother received did not have any slop, it was just right. The kit did include two little washers to add in case there was some slop.
       Post #: 29
RE: .50 size electric trex 600!!! - 7/23/2006 1:21:43 AM
credence
Status: offline
Sounds like maybe your brother got one of the revised kits? Certainly sounds like it's been a breeze to build from your posts. Hope mine goes together as easily.
Daniel
       Post #: 30
RE: .50 size electric trex 600!!! - 7/23/2006 5:16:30 AM
superhornet59
Status: offline
now that this is running off a 22v lipo... yes its expensive... yes that motor is screaming as it is. how high can you go with it?
i dont know whats above 22... but i swear, one day when i make enough money, i will buy the most powerful heli i can find (right now thats a trex 600 no doubt) swap out all the electronics and at least double the voltage. oh and ya, somehow find a motor that can take it. but if i do... watch man... im gonna make a 50 sized heli that can lift a person! HA!
custom is my middle name
       Post #: 31
RE: .50 size electric trex 600!!! - 7/23/2006 8:16:16 AM
cptsnoopy
Status: offline
I don't know if the kit was revised or not but it could have been... There have been mixed reports for several weeks. Some having troubles with little things, some no troubles with the same items at all. I am thinking we got lucky.
I got the servos mounted tonight but I did not get the rest of the links put together and installed. after that I need to set the pitch and secure the wires and a few other odds and ends, then we can give it a try. We are planning on using 4 2100 packs in a 6s-2p config for 4200mah. If that does not give long enough flight times then we will go with 6 2100's for 6s-3p. We are not looking for radical 3d, just FFF, loops, rolls and inverted hovering/forward flight. Hopefully it will handle all of that nicely.
(in reply to superhornet59)
       Post #: 32
RE: .50 size electric trex 600!!! - 7/23/2006 12:28:14 PM
credence
Status: offline
quote:
ORIGINAL: superhornet59
The .90 size electrics run off 36+ volts
I'm going to try the 3S2P packs x 2 and see how it goes. The packs I think are a bit heavier than the stock Align 6S pack, but I highly doubt the little bit of extra weight will bother the helicopter..
4 2100 packs? Sounds like alot of wiring!
Daniel
       Post #: 33
RE: .50 size electric trex 600!!! - 7/23/2006 2:33:16 PM
superhornet59
Status: offline
LOL!
wow thats absolutely crazy. the guys at my local hobby shop said this thing is 50 sized (which it is) but it has the power of 90!!! NO WAY! is it true?
       Post #: 34
RE: .50 size electric trex 600!!! - 7/23/2006 10:11:54 PM
credence
Status: offline
Probably. Electric helicopters are usually more powerful than their equivelent nitro bird, regardless of how many nitro guys refuse to believe it.
And it's simply because brushless motors are much more efficient and (in most cases) a heck of alot lighter than their nitro equivelent in power. Power to weight is almost always better on an electric helicopter.
Up untill now, though, that performance was very expensive. The t-rex 600 is the cheapest setup i've seen to date for a .50 size electric. Less than $1500 and you've got a nice .50 ship. Not much more than what you'd pay for a nitro ship. It's a good time to be an electric flyer!
Daniel
       Post #: 35
RE: .50 size electric trex 600!!! - 7/27/2006 4:19:26 PM
credence
Status: offline
Yippie Kit arrived today, though I was out flying my X-400 so missed the post man (ahh, the irony..). Gonna pick it up tommorow from the post office and start the build thread. And wouldn't you know it, with my great good luck, i've got all day tommorow off from work!
Can't wait!
Daniel
       Post #: 36
RE: .50 size electric trex 600!!! - 7/27/2006 11:41:16 PM
choppersrule
Status: offline
Good for you Credence, you deserve it. I know your as happy as lark right now. I can just see the anticipation of you opening the box and checking the parts in..
Remember, take lots of pictures at different stages of the build..and post for all to see. I'm anxious to see the whole process, I'm sure others are too.
Dave / Choppersrule
Left skid low....
       Post #: 37
RE: .50 size electric trex 600!!! - 7/28/2006 2:22:15 AM
credence
Status: offline
Will do
Daniel
       Post #: 38
RE: .50 size electric trex 600!!! - 7/28/2006 4:40:58 AM
blax1
Status: offline
Hey Guys
Have any of you seen this article?
http://www.wattsuprc.com.au/ProductPhoto/H60003announcement.pdf
Might be of some interest!
Cheers
Ralph
DF36/T-Rex 450SE/Blade CX/ SIM G3.5
Keep them choppers rotating!!
       Post #: 39
RE: .50 size electric trex 600!!! - 7/28/2006 5:38:57 AM
credence
Status: offline
I suspect that this was the reason the kits we're recalled. Now i'm glad I waited for the revised version! Nice find there blax, thanks for that! I'll be sure to double check and make sure i've got the new grips in my kit tommorow.
EDIT: Just looked closer, this PDF is dated yesterday, so this is a new problem that's been found. Upon closer reading it seems that they're implying this safety issue only appears when using something more powerful than the stock setup. Also states they believe the cause of the problem to be over-tightening of the blade bolts.
Not entirely comforting news, i'll have to keep an eye on my grips and headspeed and make sure both stay in check untill I can get some of the newer grips (or) some nice shiney metal ones .
< Message edited by credence -- 7/28/2006 5:58:22 AM >
Daniel
(in reply to blax1)
