RCtruckRacer
Joined: 6/2/2005 From: Eugene, OR, USA Status: online
Everything that I have read and experienced tells me that running 'hot' does not damage an engine. The difference in metal expansion from 270F to 320F is pretty darn small. The REAL engine killer, as has been explained, is running lean. One cannot determine how lean or rich an engine is simply by taking its temperature. There are way too many factors involved. For instance, if one changes to a carbon fiber chassis from aluminum, you may find your engine running hotter as the chassis usually works as a heat sink. Changing over to carbon fiber eliminates one source of heat dispertion, and could cause a motor to run hotter. Not leaner, just hotter. I usually only use my temp gun for break-ins.
_____________________________
Some people see the glass half full. Others see it half empty. I see a glass that's twice as big as it needs to be. My opinions are my own, and are not necessarily those of RCU
