bribeguy
AB, CANADA Status: offline
Thanx No Moa! It's first run was yesterday evening in a HUGE construction site. Terrain was everything from sand, to hard packed dirt, to baby-head sized rocks, to 30 foot hills of rock strewn dirt. In other words, large-scale-heaven. Engine fired up on about it's 6th pull after priming, and ran strong there after. Initial predictions were that the car would be a bit sluggush to control due to it's weight (this thing is nothing short of being a pig), and that the suspension would be a bit stiff. Wow, was I ever wrong! The dual 805 servo's snap the wheel's around like there is no tommorow, and the suspension works so smoothly! Its awsome to drive through a rock bed at 1/4 throttle watching each wheel travel up and down through the suspension stroke. Accelleration can only be decribed as GREAT, but unfortunately top speed is pretty weak. It's definately not as fast as a stock HPI Baja, which is a bit dissapointing, but nothing that can't be fixed in the way of different gearing or a tuned pipe. I'd say 30mph would be generous to give it as a current max. Power is crazy with the 26cc engine, and having the 4wd makes this buggy almost unstopable (litterally). It will climb up and over skull size rocks, 12 " walls, and power straight up huge hills of dirt that I wouldn't expect any RC to conquer. Brakes are strong enough to easily lock up all four wheels, and are, to be quite honest, a bit on the touchy side. Overall, I'm quite impressed, and am looking forward to taking it out again today!
_____________________________
http://www.rcthingsandstuff.com/
