bribeguy
AB, CANADA Status: offline
While the wheels will fit, it is good to note that the tires that the MCD runs with out of the box are a bit bigger in diameter then the ones typicly found on a Marder-style FG. As for your other questions jeepfreak1972: -How well does it handle and jump compared to the other large scale cars? Well! The MCD stays planted much better then a FG, and 95% as well as a Baja. The suspension seems VERY stiff compaired to a Baja when pushing down on the car, but it's amazing how much it livens up once moving. -Does it corner better than the other cars out there or does the 4x4 make it push in the turns? The 4wd makes it much easier to control in a turn. The car litterally goes where you point it. I have experiance very little puch with mine. In all actuality, I'd venture that under power, my MCD Racerunner turns better then my Brushless HPI Savage. As a bonus too, the amount of power on tap from a 26cc+ motor, allows to break all 4 tires free in a turn, and do rally-style "drift" turns. Hella fun! -Can it take the pounding of reasonable jumps? Does it fly good. My Baja like to fly nose low and it pisses me off. This all depends on what you consider a "reasonable" jump! LOL. I have not gotten alot of air time with mine yet, but the few jumps I have taken have been smooth and controlled. A decent jump and a finger on the throttle tends to yeild a nice flight path. -Is the MCD more correctable in the air because of more rotating mass from being 4x4? While the 4wd will offer you more attitude adjustment in the air then a 2wd vehicle, the MCD's weight still stops it from being as dramaticly "flicable" in the air as a 1/8 scale buggy/truck. It's definaetly more controllable then a Baja, however. -How well do the gears hold up? After a gallon of fuel in some seriously messy and dirty conditions, mine are still holding up well. There are definately some wear marks from small stones and sand getting in, but nothing that is hurting the performance as of yet. I m guessing I'll probably end up having to swap out the gears once/year or so if I keep driving in the condistions I do. Hope this helps!
_____________________________
http://www.rcthingsandstuff.com/
