sfaust
MA, USA Status: offline
[QUOTE]Originally posted by Gary Retterbush As you noted, that is a problem and is exactly why I cancelled my order a couple of years ago when I came up on the ready to ship list. I personally use the UI Profi 02 and the other one is the big Sommer unit. As I recall there is also at least one unit from the UK that is also very good. Oops. Just remembered you folks back home have 110 volts (been here too long). These units use 220. The Sommer can be had with a 12V option if that would help. URL's are: [url]www.u-i-modelltechnik.de/[/url] and [url]www.sommer-electronic.de[/url] [/QUOTE] And people wonder why Litco has a backlog, while others suggest they are bought for bragging rights LOL. The Alpha 4 is the only unit that I know of that has 4 ports, can independently charge/discharge/cycle all the batteries in a giant scale plane (usually 3 or 4 packs) at the same time all from one unit that costs less than $300. Basically, Litco hit a niche market in the giant scale arena, and has no competition at all Sure, it has some short comings. But then so do all the other chargers on the market that can't even handle multiple ports at all. Do you need multiple ports, or do you need more amps? If you need both, you are SOL, so people pick what is most important to them. That leaves 1 4 port charger, or dozens of single port higher amp chargers.
_____________________________
Stephen
