Polks C-47 electic coverted to glow
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> Polks C-47 electic coverted to glow
Page: [1]
Login
Polks C-47 electic coverted to glow - 7/10/2006 3:36:03 AM
nchrome
Status: offline
Yea you read it rite I'm in the prosess of converting an electric to glow and I have a question for all you brainy acts out there, There is defenately no room for even a hopper tank for the engines. But I have this brainstorm of using either one tank in the fuse and gravity feed the engines from it or use two tanks and gravity feed the engines. Either way the tank will be in the fuse and possibly above the carbs. My question is will either way work or should I use the mufflers and pressurize the tank to feed the engines. So far the OS 26 fourstrokers are about the same weight of the electric motors. So the wing load will be the same as what the orriginal designed. They are mounted and Bluebird micro servos for the throttles. Not realy that much was cut out of the naicels. If all goes rite then I may try to make some parachute system to deploy parachutests out the side door.
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.187RCU5
