My_Design
IL, USA Status: offline
Thanks for the reply. I just noticed that mine seems much smaller than yours. Here's the full specs from Tower: REQUIRES: Engine: .40 - .46 cu in (6.5 - 7.5cc) 2-stroke OR .52 cu in (8.5cc) 4-stroke Muffler: Standard type included with engine Radio: Four channel Servos: Five, 42 oz/in torque minimum (2-ailerons, 1-elevator, 1-rudder, 1-throttle) Servo Extension: One 6" (152mm) for ailerons Y-Harness: One for aileron servos Misc. Items: Foam rubber padding, medium fuel tubing, fuel filter, propeller, building and field equipment SPECS: Wingspan: 56.1" (1425mm) Flying Weight: 5.5 - 5.9lbs (2500 - 2700g) Length: 51.97" (1320mm) Airfoil: Fully-symmetrical, mid wing mount Center of Gravity: 4.1" (105mm) Back from the wing's leading edge at the fuselage sides. Control Throws- Low Rate High Rate Ailerons: Up & Down 0.31" (8mm) 0.47" (12mm) Elevator: Up & Down 0.31" (8mm) 0.47" (12mm) Rudder: Right & Left 1.1" (28mm) 1.6" (40mm) Does it still seem like I would need a bigger engine?
