KojakDave
FL, USA Status: offline
I have a brand new ST G90 that I just put on my H9 P-47with a Slimline Pitts muffler. I cut the metal exhaust extensions approximately 1/4" to 1/2" each and then mounted silicone exhaust deflectors so that the cowl could be mounted but the exhaust would exit the cowl. The engine was run in according to the directions in the manual and seem to be doing wonderfully. I also took the plane up for its maiden and it ran like a top; plenty of power, great transition, and a healthy amount of smoke. On the second outing, however, I ran into a problem. The engine was running extremely lean and I could turn the high speed needle valve at least 6 or 7 turns out (3 is the recommended rich setting for this engine). Also, I had a hard time getting the engine to shut down, even with the carb completely closed. I suspected an air leak so I changed out all of the fuel lines and reseated the carb with some red silicone high temp gasket maker. I started the engine up again today and it is still overheating and running lean (it fails the pinch test even at 6 turns out). I noticed that a lot of exhaust and oil seemed to be coming out of the joint between the engine and the muffler. I pulled the muffler off and the gasket that came with the engine was torn, so I removed it and made a gasket out of the red high temp silicone gasket maker. Is it possible that the pressure leak between the engine and muffler was causing the engine to run lean (i.e. not enough back pressure)? Also, would this still cause the engine to act like there was an air leak, as I again had trouble shutting the engine off? I am getting very tired of fiddling with a brand new engine, and am wondering if I should just send it back to the manufacturer for a new one. I have not made any permanent modifications to it, simply applied some silicone around the carb and muffler joints. I have also thought about plugging one of the exhaust outlets to see if that helps, but it ran so well on the maiden, why would it suddenly change like that? Also, the idle stop screw fell out during the maiden, but Bax (of the ST support thread) said that there shouldn't be any air leaks caused by that because it only catches the outside of the carb barrel and doesn't have anything to do with the actual air intake. Can anyone think of anything else? I wanna fly this plane, not tinker with the engine! Thanks, Dave
_____________________________
Dave It's better to break ground and head into the wind than to break wind and head into the ground
