KojakDave
FL, USA Status: offline
What a day...I took her out to the field today and things just did not go right. The first flight she was definitely too rich. She didn't have enough power and it looked almost like I was skywriting, there was that much smoke coming out. Brought her in and adjusted her a little leaner, then took her back up. It just so happens I almost crashed her because somebody was running a 1/3 size Telemaster/Cessna hybrid on the ground and I couldn't hear the engine quit. I had fueled her back up, but because she was running so rich she went through the fuel like crazy and emptied the tank!! Then the problems started. I again leaned her out a little. On the ground she was awesome, excellent idle, great transition, and still a little rich on the top end (it is still being broken in, I'd rather run a little rich than burn her up). But when I took off this time, she deadsticked after just a minute. Hmmm, brought her in, got her running on the ground, decided to let her run for a while, do a few transitions, etc....sounded great. Started idling, got her out on the runway and I had a nose-over. Oops, pilot error. Walked out, started her there, let her run for a sec, throttled up, and she died. I decided that the Gods were not smiling, packed her up, and am now ready to see what the problem is where I can curse in the privacy of my own home. One of the maestros at the field (I think old-timers sounds disrespectful) said that an Enya #3 glowplug might help. I'm running the SuperTigre glow plug that came with the engine. Anybody have any input on this? I don't think I leaned her out too much because she's still smoking and passes the pitch test (you know, throttle up and somebody points her nose up, if she revs up a little she's good, if she dies off she's too lean). As far as overheating I checked the engine after her first full flight and she was not what I would consider too hot, I could touch my finger to the cylinder head for a second without getting blisters  |
