KojakDave
FL, USA Status: offline
Cyclic Hardover, First of all, when I first experienced the overheating it was while I was flying. And yes, it still did this with the cowl off, too. What confused me was that I had flown it previously just before the problem started without any problems. Next, I checked for air leaks, replaced fuel lines, and siliconed the muffler gasket. Now this whole time I am attempting to retune the engine, but guess what..without the necessary back pressure to deliver the fuel required to run the system, you can turn that needle open all you want but no more fuel is going to make it to the carb. When I plugged one of the exhaust outlets I was able to then correctly tune the engine. Now, I know that I am not the only person who has had to do this to a Pitts muffler because there are around 200 threads about it having to do it (an exaggeration, I know, but after someone suggested that was the problem I did a search and discovered that there have been a LOT of people who plugged a pitts muffler)... does that mean that everyone that has to do this is an idiot? No, it does not. As far as asking about whether the NEW dummy engine (with only a space for the cylinder cut out) would cause overheating, that was AFTER I fixed the original problem with the engine. The original dummy engine was entirely cut out all around except for the dummy cylinder heads AND a space in front of the actual cylinder. I was just looking for comments from folks in this thread without having to start a whole other thread on such a similar topic. Now, I appreciate constructive criticism and am always asking for help from more experienced folks in the hobby, but I don't agree with your "my way is the only way and everyone else can't tune the engines because they're stupid" attitude. How about being a little more helpful and a little less judgemental. If everyone believes me to be wrong for this post, just let me know and I will gladly remove or edit it. Thanks, Dave
< Message edited by db4962 -- 7/27/2006 8:21:58 PM >
_____________________________
Dave It's better to break ground and head into the wind than to break wind and head into the ground
