color0
Joined: 12/22/2005 From: Cupertino, CA, USA Status: offline
Gah... I'll list out all I can think of. Front suspension: - 0 degrees camber - 0 degrees caster - 0 degrees toe out - 3racing stiff spring (I think it's 3racing...) - 3racing kingpins - lowered 1.5mm Rear suspension: - stiff t-plate - gear diff (don't use that... try to use a ball diff) - disk damper: furniture polish as lube, soft top spring, stiff bottom spring - lowered 1.5mm Motor/gearing: - Hyper dash 2 armature, ball bearing can, carbon brushes, neodymium magnets - 44:6 gear ratio Tires: - front: plastic - rear: 55 degree (shore hardness, I think?) Chassis overall: - wheelbase: 98mm - width: 70mm
_____________________________
Greyscale Racing
