Will CX Charger work on 3 11.1V LIPO ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Will CX Charger work on 3 11.1V LIPO ?
Page: [1]
Login
Will CX Charger work on 3 11.1V LIPO ? - 7/12/2006 4:16:12 PM
jgeorgic
Status: offline
Will my balance charger that I have with my CX work on 3 cell 11.1 V LIPO's ?
       Post #: 1
RE: Will CX Charger work on 3 11.1V LIPO ? - 7/12/2006 5:39:57 PM
BarracudaHockey
Status: offline
I'm not sure what type of charger that is but I can tell you this: If its not a LiPo charger then DON'T use it on LiPoly batteries.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to jgeorgic)
       Post #: 2
RE: Will CX Charger work on 3 11.1V LIPO ? - 7/12/2006 6:35:46 PM
Gonwee
Status: offline
If it has a 3 cell balance connector, it will charge a 3 cell battery, if its the stock charger then i don't know, it might only be compatible with a 2 cell lipo.
(in reply to BarracudaHockey)
       Post #: 3
RE: Will CX Charger work on 3 11.1V LIPO ? - 7/12/2006 8:07:28 PM
jgeorgic
Status: offline
The charger is a stock eflite charger that I use with my Blade CX.That is for the 800aMh 2 cell lipo battery.
SO will that charger work on a 3 cell lipo ?
(in reply to Gonwee)
       Post #: 4
RE: Will CX Charger work on 3 11.1V LIPO ? - 7/12/2006 8:10:31 PM
Wazmo
Status: offline
I believe it is designed to work only with the E-Flite 2 cell LiPo. As I recall, the balance/charge connector has only three pins, which isn't enough to balance charge a 3 cell. It might be possible to modify it to work with a 3 cell, but you're taking a big risk there. You can get a decent LiPo charger for about $50-100.
       Post #: 5
RE: Will CX Charger work on 3 11.1V LIPO ? - 7/12/2006 8:18:21 PM
manse
Status: offline
It won't work with a 3 cell, it will only work with a 2cell battery.
The Thunder Power 425 is a nice 2 - 5 cell charger, 45 bucks or so. I have one and it is great.
The Great Planes LiPoly 4 charger is also a nice one, lets you charge 4 batteries at once. $100
Both of these need a DC power source, either a car battery or a AC/DC converter. These run $50 and up.
Note that the above chargers are not balancing chargers, so you may want to get a Balancer as well. I use a TP-205.
But that is for my airplane batteries. For the CX, I use the included charger are AC Adapter.
If you get a Blade CP Pro , then it comes with the 3-cell charger, which I believe can use the same AC adapter from the CX.
EDIT: Poster below is correct. I meant to say CP Pro in my initial email. Sorry.
< Message edited by manse -- 7/18/2006 5:59:41 PM >
(in reply to Wazmo)
       Post #: 6
RE: Will CX Charger work on 3 11.1V LIPO ? - 7/15/2006 8:26:40 AM
Zelatio
Status: offline
quote:
ORIGINAL: manse
If you get a Blade CP, then it comes with the 3-cell charger, which I believe can use the same AC adapter from the CX.
The CP comes with a NiMH charger for the NiMH battery it comes with. The CP Pro on the otherhand comes with Lipo batteries.
E-Flite Blade CP - E-Flite Blade CX - ThunderCat 31
(in reply to manse)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU5
