Zenoah stats
Tower Hobbies
Logged in as Guest
  Printable Version
202oz Servo With Money Back Guarantee
Seller:  monstertruck2000
Details:   $17.95   |  1/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Zenoah stats
Page: [1]
Login
Zenoah stats - 7/12/2006 10:47:42 PM
Soloratov
Status: offline
This is another measurement favor, figured I'd get that out first.
I know there are like 3-4 different engines used in these cars, but I am looking for a general size of the engines. More or less, if you were to put it in a box, how big would it have to be?
Looking for height, width and length, generally, of your engines........JUST THE ENGINES, not the pipe.
_____________________________
UBER HUGE SCALE!
Mod it 'til it breaks.
       Post #: 1
RE: Zenoah stats - 7/13/2006 3:57:02 AM
J_D
Status: offline
i htink they weigh like 2.8 kg.
and go in a box of like, 20 x 20 x 20 cm
Zenoah Powered FG Marder
(in reply to Soloratov)
       Post #: 2
RE: Zenoah stats - 7/13/2006 4:38:23 AM
Soloratov
Status: offline
An 8" cube!? Really? Thats really small.........my dual engine may work if thats true....anyone else?
UBER HUGE SCALE!
(in reply to J_D)
       Post #: 3
RE: Zenoah stats - 7/13/2006 4:57:54 AM
J_D
Status: offline
thats a rough guess :P
what sort of dual engine? and how are u gunna mount it.
< Message edited by J_D -- 7/13/2006 4:58:27 AM >
       Post #: 4
RE: Zenoah stats - 7/13/2006 5:13:10 AM
Soloratov
Status: offline
Well, assuming the ingines can be mounted at an angle, like this one......
http://www.thorbob.com/baja_project_intro.htm
in a 16 inch space across the frame of my truck, then I will use that same general layout, with a shaft running to my transmission, and then a chain to the rear diff. It's all a matter of space as far as thats concerned. I have roughly a space that is 16"x18" to fit the engine/engines, tranny, and gas tank. However, I may be putting the tank over the tranny to conserve space, and allow for a larger capacity if I use two engines. We'll see.
UBER HUGE SCALE!
(in reply to J_D)
       Post #: 5
RE: Zenoah stats - 7/13/2006 5:30:50 AM
J_D
Status: offline
those are tiny little nitro engines though.
       Post #: 6
RE: Zenoah stats - 7/13/2006 11:19:47 AM
Soloratov
Status: offline
Yes, I know, whats the problem? I can use the same layout and scale it up to fit a zenoah.
UBER HUGE SCALE!
(in reply to J_D)
       Post #: 7
RE: Zenoah stats - 7/13/2006 1:09:26 PM
kengentry5000
Status: offline
Man that truck LOOKS incredible! Excellent craftsmanship.
I couldn't imagine what would be involved to scale that up for a couple of Zenoah G260 engines. Considering the driveline layout of the engines they would probably have to be 'sideways' compared FG or HPI gassers, right? The weight is going to be a challenge. If the same basic construction techniques are used and two engines mounted I bet the gasser version would weigh 40 pounds+.
Definitely keep us posted Soloratov if you develop some ideas. Even basic drawings would be interesting to see.
Good Luck!
Firehammer with Zen 26cc and FG 8485 limited slip diff (no more "sit and spin" - just hooks up and goes).
       Post #: 8
RE: Zenoah stats - 7/13/2006 10:16:19 PM
Soloratov
Status: offline
Ok, hows this.........
So far, the stats are as follows:
Length: 49" or 1244.6mm
Width: 29" or 736.6mm
Height: TBD depends on suspension setting, and engine height.
Goal weight: 65lbs
The plan for the engines is fairly esay, if they fit. I'll make a larger size pair of angles similar to the other guys project, and mount that right behind the steering arms.
< Message edited by Soloratov -- 7/13/2006 10:20:39 PM >
UBER HUGE SCALE!
(in reply to kengentry5000)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.593RCU5
