35% extra 260 QB
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> 35% extra 260 QB
Page: [1] 2   next >   >>
Login
35% extra 260 QB - 7/13/2006 5:37:33 AM
SU-13
Status: offline
i was wondering, does the 35% QB 260 come with a smoke tank?
       Post #: 1
RE: 35% extra 260 QB - 7/13/2006 2:09:27 PM
bodywerks
Status: offline
The future shipments of them will. The first shipment, the one that has sold out, did not have the tank. The red ones coming in a month or so should have the smoke tank, throw meter, pre-drilled holes for the control arms, and all SAE hardware.
_____________________________
STRAIGHTEN UP AND FLY LIGHT!!!
(in reply to SU-13)
       Post #: 2
RE: 35% extra 260 QB - 7/13/2006 6:08:28 PM
SU-13
Status: offline
cool. and just wondering. how does it fly?
(in reply to bodywerks)
       Post #: 3
RE: 35% extra 260 QB - 7/13/2006 8:11:33 PM
sweetpea01
Status: offline
One word......
Fricking superb. I guess that's two words
www.propnuts.org
www.hobbiesxtreme.com
(in reply to SU-13)
       Post #: 4
RE: 35% extra 260 QB - 7/14/2006 9:19:40 AM
bodywerks
Status: offline
Ditto. It is rock-solid in upright harriers and a trainer in inverted harriers, shows a good pitch departure in the snaps without sending it way off track. The wings are very light, which makes rolls start and stop on a dime. It is an absolute floater at 25.5 pounds, even at my 6500 foot altitude, and it is a very predictable flyer. The only thing I found that will take some time to set up perfectly is aileron differential. The manual doesn't suggest any, but I found that I do need some. Once I get the CG and right thrust worked out, I will tackle the differential and have a super, super sweet flying plane, as opposed to the super sweet flying plane I have now!
(in reply to sweetpea01)
       Post #: 5
RE: 35% extra 260 QB - 7/14/2006 4:56:11 PM
SU-13
Status: offline
does aileron diffrential effect when you roll, or just when you turn?
       Post #: 6
RE: 35% extra 260 QB - 7/14/2006 7:38:28 PM
sweetpea01
Status: offline
more when you roll than in a turn. You can learn to fly around it, but with modern radios its easier to just program it out.
www.propnuts.org
(in reply to SU-13)
       Post #: 7
RE: 35% extra 260 QB - 7/14/2006 10:03:49 PM
SU-13
Status: offline
wat servos are you guys using on this plane?
       Post #: 8
RE: 35% extra 260 QB - 7/15/2006 2:57:50 AM
sweetpea01
Status: offline
I was using 8411's on the ailerons and 8611A's everywhere else.
But I had the cases to my 8411's break (they were used in my 1/8 scale R/C car so I'm not surprised).
So right now I have 8611's on one side and 8411's on the other until my new cases and gears arrive for the 8411's.
So for now I'm not adding differential till I go back to the same servos on each wing
www.propnuts.org
(in reply to SU-13)
       Post #: 9
RE: 35% extra 260 QB - 7/15/2006 3:04:45 AM
tomswrld
Status: offline
Hi SU-31. I am using 4 Hitec5645s on ailerons, 2 Hitec5945s on elevators, 1 Hitec5955 ( ! ) on rudder, and 1 Hitec 425 on throttle. I stick my finger through a hole in the bottom of the cowl for choke. Futaba 9 ch. PCM rec. DA 100 with stock mufflers. Stock everything else, as it came from Aeroworks. 2 TBM 2800 Li-Ons with Maxx Miracle switches and 6 volt regulators on receiver. 1 1500 4cell Expert NiMH with JR heavy duty charge switch on ignition. If I get bucks-up I would like to replace each servo with Hitec 5955s all around. Tom
(in reply to SU-13)
       Post #: 10
RE: 35% extra 260 QB - 7/15/2006 3:50:08 AM
SU-13
Status: offline
cool. i was wondering. they have glow planes(3d). they have gas planes (3d) comapre these 2.
funtana 90 or extra 260 QB
Funtana 40 or 29% awx edge 540
(in reply to tomswrld)
       Post #: 11
RE: 35% extra 260 QB - 7/15/2006 10:48:08 PM
bodywerks
Status: offline
No comparison whatsoever for either of them. The smaller planes are always a lesser flyer. Both of the Funtanas have pretty bad wing rock in 3D, the QB doesn't. Hope that helps.
(in reply to SU-13)
       Post #: 12
RE: 35% extra 260 QB - 7/16/2006 3:38:01 AM
SU-13
Status: offline
i am only afraid of the price of these planes. the engine, the plane, the servos. its like hell
       Post #: 13
RE: 35% extra 260 QB - 7/16/2006 3:44:15 AM
sweetpea01
Status: offline
safest investment for large scale. The airplane is being used in both 3-D and IMAC very well.
It lands better than a trainer. Unlike Bodywerks....mine is in the 28-29lb range and flies likes its around 24lbs
(I've got larger batts and cans)
www.propnuts.org
(in reply to SU-13)
       Post #: 14
RE: 35% extra 260 QB - 7/23/2006 1:25:06 PM
Jecarte
Status: offline
I bought mine used RTF from a guy getting out of the hobby and if flies just like everyone says. If anything ever happens to this one I will buy another one for sure.
       Post #: 15
RE: 35% extra 260 QB - 7/23/2006 7:27:14 PM
bodywerks
Status: offline
The only improvement I could make to this plane would be an electric conversion!
(in reply to Jecarte)
       Post #: 16
RE: 35% extra 260 QB - 7/24/2006 4:33:44 AM
mxcop114
Status: offline
Hey I see you have a QQ YAk. I have the 85"er. I was wondering how you would compare the 260 to the Yak, I know they are totally different designs but I'm wondering how they compare. I am really thinking about buying the 260 since I have yet to see a bad thing about it.
Team JR / Horizon Hobby
Team Extreme / Extreme Flight RC
