Geistware
GA, USA Status: offline
Here is the post from the other thread. Look at it this way. With the 150% autoshutoff, you can set the exact maH you want in a pack. Just set it and when it shuts off for capacity, you are done. To me this is better than a timer or a wall wart which will have it's charger current change slightly with cell resistance, number of cells in a pack, and cell voltage. -------------------------------------------- I use 1800maH NiCad packs. I want to charge it at C/10 for 12 hours. C/10 is 180ma times 12 hours or 2160ma I then multiply this times 2/3 and get 1440maH. I set it for 1500maH and know the pack will only run for 12.5 hours before it shuts off for over charge. I don't have to worry about the pack getting too hot due to a charger failure. I do the same thing for a quick charge. If I think half the pack is gone, I set it to charge a C or 1.8 amps but say the capacity is 2/3 of half or 1800/2*0.67 or 600maH. The charger will not put more than 900maH into the pack. If the pack is completely down to 1.1 volt per cell. I just say it is a 1200maH pack and charge it at 1.8 amps. Since doing this, I have NEVER damaged a pack.
_____________________________
Aircraft Proving Grounds http://www.rcaircraft.net/ Information on the building and flying of Radio Control Aircraft. Site for hobbyist in the R.C. Aircraft modeling world.
