RE: Nitro Fuel and Zippo? (Full Version)
All Forums >> [Glow Engines, Gas Engines, Fuel & Mfg Support Forums] >> RC Fuels
Message
pilotpete2 -> RE: Nitro Fuel and Zippo? (11/18/2006 11:27:40 PM)
quote:
ORIGINAL: asmund
use 30% nitro and at least 24% oil to ensure reliable and powerful lighting, the extra oil will lube and cool the zippo and make sure it doesn`t seize. Happy smoking[sm=bananahead.gif]
asmund,
It sounds like you're already suffering from the lack of daylight, what are you going to be like when we bottom out at winter solstice??[:)] Scary thought[:D]
Only kidding[;)], how far are you from the Arctic circle?
Pete
asmund -> RE: Nitro Fuel and Zippo? (11/19/2006 8:07:42 AM)
yeah, not much daylight around here now, flying can only be done between 11-15 o`clock (were it not for the wind and rain). I am about a 10 hour drive from the Arctic circle. I am just sitting here in the dark trying to be funny[;)]
jetpack -> RE: Nitro Fuel and Zippo? (12/16/2006 5:21:37 PM)
Rosonol lighter fluid is composed of mainly one ingredient...Naphtha.
It can be purchased by the quart or the gallon at any good hardware store - it says "NAPHTHA" right on the can.
As far as using rc fuel in a Zippo lighter - within an hour of filling it you will have evaporated all of the nitro and left with primarily a mix of Methanol and Oil, then a day after that you will be left with simply Oil in the wicking.
The next refill will only dilute the Oil, until all your left with is a runny, oily lighter that stinks like Castor.
asmund -> RE: Nitro Fuel and Zippo? (12/16/2006 7:09:06 PM)
I just wonder, why not just use Zippo lighter fuel? It`s not like you use it by the gallons or???? Heavy smoker??[:D]
Sport_Pilot -> RE: Nitro Fuel and Zippo? (12/20/2006 1:52:15 PM)
When fuel is left open, the methanol evaporates first. But even methanol evaporates slower than naptha. Look up the flashpoints and vapor pressures instead of making assumptions.
davispotozny -> RE: Nitro Fuel and Zippo? (6/21/2007 2:24:05 AM)
can you spray perfume in the zippo for fule?...
Page: <<   < prev  1 [2]
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.171875
