P-51B
Joined: 10/11/2002 From: An Iceburg in, ANTARCTICA Status: offline
Well, I finally got to maiden my cubby with the 25 on it this weekend. The take off was, shall we say hair raising! Once in the air it flew nicely, and could readily be put into a spin. I also learned that the CG range is large. I had a new pak in it...that I forgot to put velcro on the bottom of. Well, the velcro holding strap allowed the pack to slide all the way back to the servos putting the CG about an ince behind the back of the recommended range, but the plane still handled well (as I found this after landing). The 25 seemed to be good power for it. It would climb vertically for quite a while, and I could easily power out of trouble that I put it into to test this. The second flight...still had a hair raising takeoff. The landings are beautiful, it really likes to come in on the mains! I went home and put the floats on it last night. Weather permitting it will get is float maiden this Sunday at one of my clubs picnics. Oh, it will also be my first time flying off water! I haven't mounted the extra vertical stabilizer (under the fuze) yet, is it really needed on the cub with floats?
_____________________________
In order to think "outside the box", one must first accept there IS a box.
