RE: E-flite J-3 Cub 25 ARF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Aerobatic & Sport Planes >> RE: E-flite J-3 Cub 25 ARF
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: E-flite J-3 Cub 25 ARF - 7/31/2006 1:20:15 PM
Greg Covey
Status: offline
The E-flite 25 motor attaches to the pre-mounted t-nuts in the firewall. Remember to use some thread locker on these screws as well as the screws holding the X-mount to the motor. I decided not to mount the ESC to the side wall with Velcro (hook and loop) as it is held in position quite well by the thick wires and battery pack. We'll see if this works out during actual use.
The cowl was held in place while I drilled pilot holes for the 4 mounting screws. Some folks like to use masking tape to temporarily hold the cowl in position while drilling.
The prop adapter is designed to fit the APC 12x6 e-prop perfectly without and bushing. The collet design simply presses in place and is then tightened. I use the largest size hex wrench that will fit through the hole in the spinner to tighten it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Greg Covey -- 7/31/2006 1:30:33 PM >
_____________________________
Visit my Web Hangar at www.gregcovey.com/rc.htm
(in reply to Greg Covey)
       Post #: 26
RE: E-flite J-3 Cub 25 ARF - 7/31/2006 1:36:26 PM
Greg Covey
Status: offline
I charged the ThunderPower 4200mAh pack with a Cellpro 4s Balancing Charger and ThunderPower to Cellpro Adapter from FMA Direct. All three products are available from Horizon Hobby.
Since this charger can safely recharge the pack in the plane, I mounted the battery with Velcro on the bottom and two Velcro straps. This combination holds the 10oz pack securely in place without any sliding. Note that the fuselage hatch is held in place by two strong magnets.
Click for fullsize
Click for fullsize
< Message edited by Greg Covey -- 7/31/2006 1:41:11 PM >
       Post #: 27
RE: E-flite J-3 Cub 25 ARF - 7/31/2006 3:02:08 PM
Charley
Status: online
quote:
ORIGINAL: Greg Covey
SNIP
Whoa! I thought you were going to try the NiMH pack first. Or was that too?
A friend of mine is putting a Cub together. He's using two 2100s in parallel to hold down the battery cost and be able to use them in other E-birds.
CR
Charley
ccrobins@ktc.com
       Post #: 28
RE: E-flite J-3 Cub 25 ARF - 8/1/2006 2:20:22 PM
Greg Covey
Status: offline
Hi Charley,
I haven't tried anything yet...it's only a picture of the mounting scheme and safe charging technique. Keep in mind that two 3-cell 2100mAh ThunderPower packs are no less expensive than a single 3s2p 4200mAh pack.
The struts simply screwed into place using the supplied hardware and pre-tapped holes.
Click for fullsize
(in reply to Charley)
       Post #: 29
RE: E-flite J-3 Cub 25 ARF - 8/1/2006 5:33:32 PM
Greg Covey
Status: offline
The finished E-flite J3 Cub 25 balanced perfectly with either pack installed and weighed 59oz (3.7lbs) Ready-To-Fly (RTF).
The power system measured 350 watts at 33amps for about 95w/lb which guarantees aerobatic performance.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 30
RE: E-flite J-3 Cub 25 ARF - 8/1/2006 9:20:55 PM
Charley
Status: online
Hi Charley,
Not necessarily, Greg. Besides, we don't all use Thunder Power packs. I have Kokam & Common Sense packs, some others. Flexibility is also a consideration.
BTW, the two 2100s fit fine if stood on edge.
Looking forward to the flight testing.
Cheers,
CR
< Message edited by Charley -- 8/1/2006 9:22:29 PM >
Charley
ccrobins@ktc.com
       Post #: 31
RE: E-flite J-3 Cub 25 ARF - 8/3/2006 6:12:22 PM
donjiskra
Status: offline
Greg,
Your step-by-step photos and remarks are excellent.
As always, you are a true master, I learn much from you.
I plan on getting this plane, as a replacement for my Hobby Lobby "Bonnie", which I recently demolished. The "Bonnie" is/was an incredible flyer, especially with floats.
I plan on using the AXI 2820/10 motor that was in the "Bonnie" and the 4200mah lipo, whioch provide 20 minute flights on a 10x7 APC-E prop.
Can't wait to read about your flight review and see te video.
BTW, the gentleman that asked about using skis.
I found that floats work much better, as my experience with skies, showed they tend to dig into light snow.
Thanks Greg, for taking the time to write and provide such great photos with awesome resolution.
Happy flying.
Don
       Post #: 32
RE: E-flite J-3 Cub 25 ARF - 8/4/2006 8:37:59 PM
Greg Covey
Status: offline
Hi Don,
Thanks. Sorry to hear that your Bonnie 20 met with demise. It is a similar size to the E-flite J3 Cub 25 so you should be a happy R/Cer once again. The .25-size planes have some advantages in that they are manageable by most as an all occasion flier. The quick change floats on the J3 Cub 25 enhances that property even further.
The 10-cell E-flite 1800mAh 4/5A NiMH pack mounts in the same manner as the optional LiPo pack. It adds another 3oz to the flying weight.
The Expert (EXRB100) 4-cell, 4.8v, 720mAh AAA NiMH receiver pack adds another 2oz and is best mounted across the CG as shown when using the LiPo pack. It can also be mounted below the servo tray on top of the framework for the gear mains. When using the 10-cell E-flite NiMH pack that weighs 12.8oz, move the Expert receiver pack aft by about 3" for proper balance.
The Expert receiver pack is used in conjunction with the Expert (EXRA050) Standard Switch with charging cord so you recharge it right in the plane. This eliminates the possibility of a BEC failure under extreme heat, humidity (thicker air), and servo drain conditions. I am not certain if it has been determined that this conditions happens often enough to justify the setup. It is a recommendation by Horizon Hobby for safety due to the specifications of the ESC's BEC output.
The 8% range of flying weight due to various setup is as follows:
  • 59oz (3.7lbs) with LiPo option and using BEC in ESC
  • 62oz (3.9lbs) with NiMH battery pack and using BEC in ESC
  • 64oz (4.0lbs) with NiMH battery pack and using Expert receiver pack
Click for fullsize
Click for fullsize
< Message edited by Greg Covey -- 8/4/2006 8:40:50 PM >
(in reply to donjiskra)
       Post #: 33
RE: E-flite J-3 Cub 25 ARF - 8/4/2006 11:34:42 PM
matt7rc
Status: offline
i bought the e-flight j-3 cub for its size and looks but i cant get use to batteries so right out of the box i straped a o.s 25 la on her and let me tell you the thing is a blast to fly
       Post #: 34
RE: E-flite J-3 Cub 25 ARF - 8/5/2006 3:19:45 AM
Charley
Status: online
quote:
ORIGINAL: matt7rc
The word is "strapped."
CR
Charley
ccrobins@ktc.com
(in reply to matt7rc)
       Post #: 35
RE: E-flite J-3 Cub 25 ARF - 8/5/2006 3:44:00 PM
Phoenex
Status: offline
quote:
ORIGINAL: Charley
quote:
ORIGINAL: matt7rc
CR
This is not an English class forum...get over it
       Post #: 36
RE: E-flite J-3 Cub 25 ARF - 8/6/2006 2:56:14 PM
Charley
Status: online
quote:
ORIGINAL: phoenex
You need help too; the word is "phoenix." ;^) Or is that some sort of play on the word?
On a more serious note; I wonder how long it will be before that OS 25 shakes the Cub's nose apart.
CR
Charley
ccrobins@ktc.com
(in reply to Phoenex)
