John Redman -> RE: E-flite J-3 Cub 25 ARF (8/12/2006 3:00:36 AM)
Follow the instructions on taxing and take off with floats and you shouldn't see any water up in the battery area. If you fly when there is small chop on the water, then you will see some small amount of water make it into the battery area. Either way it isn't a big deal. My Cub has better than 200 landings on it and I would venture to guess better than 100 flights on it since I put it together, it is still wokring without issue. We haven't seen any real problem with the rudder not coming back to center when it is attached to the water rudder. As mentioned you might want to trim the plastic housing a bit to eliminate some of the binding I am sure you have. I thought the picture showed more or less where to cut it off in the instructions, it might not. The tube length needs to work with both teh Cub and Ultra Stick 25e (which needed to be a bit longer). Another question would be what servo do you have on the rudder. We tested the plane with JR Sport MN-48's and never had the problem. As stated in the instructions, bury your elevator for the start of the take off run when on floats, and once speed begins to build, begin to relax the elevator until she comes up on step. The process moves along very quickly and you will be in the air in less than 250 feet once you get used to it. I think you will really enjoy it on the water, I know I do.
