RE: E-flite J-3 Cub 25 ARF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Aerobatic & Sport Planes >> RE: E-flite J-3 Cub 25 ARF
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: E-flite J-3 Cub 25 ARF - 8/11/2006 6:07:55 PM
Tall Texan
Status: offline
I can't tell any difference in the water left or right. You are right, I should have noticed that. Sometimes with these ARFs you get so tied into to following instructions you just overlook. Haven't actually flown it as yet. Just got my radio back from JR and had it on the lake yesterday doing some taxiing. Don't know yet if I am going to see any water in the battery area from the vent holes in the hatch. Hope to fly it this weekend.
(in reply to Charley)
       Post #: 51
RE: E-flite J-3 Cub 25 ARF - 8/11/2006 10:21:08 PM
FlyingGuy
Status: offline
Hi Gents. Anyone hand-launch the E-Flite Cub and recover it in high grass, sans landing gear? My favorite field is the home of the belly landing. Thanks!
_____________________________
AMA 854011
(in reply to Tall Texan)
       Post #: 52
RE: E-flite J-3 Cub 25 ARF - 8/12/2006 3:00:36 AM
John Redman
Status: offline
Follow the instructions on taxing and take off with floats and you shouldn't see any water up in the battery area. If you fly when there is small chop on the water, then you will see some small amount of water make it into the battery area. Either way it isn't a big deal. My Cub has better than 200 landings on it and I would venture to guess better than 100 flights on it since I put it together, it is still wokring without issue.
We haven't seen any real problem with the rudder not coming back to center when it is attached to the water rudder. As mentioned you might want to trim the plastic housing a bit to eliminate some of the binding I am sure you have. I thought the picture showed more or less where to cut it off in the instructions, it might not. The tube length needs to work with both teh Cub and Ultra Stick 25e (which needed to be a bit longer). Another question would be what servo do you have on the rudder. We tested the plane with JR Sport MN-48's and never had the problem.
As stated in the instructions, bury your elevator for the start of the take off run when on floats, and once speed begins to build, begin to relax the elevator until she comes up on step. The process moves along very quickly and you will be in the air in less than 250 feet once you get used to it.
I think you will really enjoy it on the water, I know I do.
John Redman; Team JR, BVM Rep, JetCat USA Rep, Horizon Hobby/E-flite Product Developer/Manager
(in reply to FlyingGuy)
       Post #: 53
RE: E-flite J-3 Cub 25 ARF - 8/13/2006 5:09:18 PM
Greg Covey
Status: offline
The float assembly went without a problem as the instructions were simple and well written. The J3 Cub 25 is also a float-ready design by E-flite.
After removing the stock gear mains, I cut the covering off the rear most channel and mounted the float mains. Next, the brackets were screwed into the floats and flat spots filed onto the tops of the float mains for better hold by the wheel collar set screws. I used a Dremel tool grinder to make the entire top of the float mains extensions flat.
The floats were then mounted and the collars secured using Pacer Z-42 Thread Locker. Note that there is one float with extra holes in the aft end that is meant to mount on the side were the rudder linkage is located.
The ventral fin mount is screwed into place in the pre-drilled holes under the Cub fuselage. After cutting away some covering, the fin itself is glued into the mount with epoxy. I used 5-minute ZAP Z-poxy.
Next up...linkage and water rudder installation.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Greg Covey -- 8/13/2006 5:17:03 PM >
Visit my Web Hangar at www.gregcovey.com/rc.htm
(in reply to John Redman)
       Post #: 54
RE: E-flite J-3 Cub 25 ARF - 8/13/2006 7:02:27 PM
Charley
Status: offline
quote:
ORIGINAL: John Redman
250 feet? Is that a typo? My GWS Tiger Moth 400 gets off the water in <25 feet and that's on the stock can motor with a 3 cell LiPo.
CR
Charley
ccrobins@ktc.com
       Post #: 55
RE: E-flite J-3 Cub 25 ARF - 8/14/2006 3:42:24 AM
John Redman
Status: offline
No that isn't a typo. 250 feet is a normal run on water with a 5.5 pound bird. How much does your Tiger Moth weigh?
       Post #: 56
RE: E-flite J-3 Cub 25 ARF - 8/14/2006 1:19:07 PM
Greg Covey
Status: offline
John,
The TM400 is a smaller foamie parkflyer that weighs about 20-24oz with floats. It isn't a valid comparison...much like apples to oranges. You can see my review on it here.
We have already decided that the J3 Cub 25 should not be considered a parkflyer due to its size, weight, and power level.
< Message edited by Greg Covey -- 8/14/2006 1:21:30 PM >
       Post #: 57
RE: E-flite J-3 Cub 25 ARF - 8/14/2006 1:53:30 PM
Charley
Status: offline
Got to admit that my TM-400 weighs less than 2 lbs with the floats and water rudder and it has lots of wing area too. But it's powered by the stock, geared, speed 400 brushed motor.
John, I'm not knocking your Cub, after all it's your rice bowl, but 250' is almost the length of a football field. I've done lots of float flying with models ranging from .10 to .60 size and if any of them wouldn't get off in less distance than that, I'd be seriously concerned about my setup.
I have a feeling you're over estimating the TO distance of your Cub. Maybe Greg can get us an estimate during his upcoming ROW test flights.
CR
Charley
ccrobins@ktc.com
       Post #: 58
RE: E-flite J-3 Cub 25 ARF - 8/14/2006 10:02:36 PM
Greg Covey
Status: offline
Yeah, we can test a scale take-off and then see what it can do on full throttle. Assuming calm water, it's a blast to let it ride on step for a while.
The water rudder and linkage assembled fine and I did not see any excessive resistance added to the rudder throw. My only modification was to make two of the full brass strips into half strips for easier mounting. I used a Dremel tool to cut off the unwanted end.
I also managed to break one of the quick links so I replaced it with a similar size one from my own supply. There was about 1/2" excess cable that I cut off from the float end.
When testing the water rudder assembly, make sure that it follows the normal rudder direction and that it can flip up with little resistance if it hits a rock or some obstruction in the water.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Greg Covey -- 8/14/2006 10:08:16 PM >
       Post #: 59
RE: E-flite J-3 Cub 25 ARF - 8/14/2006 10:10:08 PM
Greg Covey
Status: offline
The Cub looks great with the floats attached. I can't wait to test it out but I must travel for work this week. Perhaps this weekend sometime.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Greg Covey)
       Post #: 60
RE: E-flite J-3 Cub 25 ARF - 8/15/2006 2:13:18 PM
Greg Covey
Status: offline
I mounted the On/Off switch in-line with the black stripe to keep it from detracting from the scale look of the Cub. You can either re-route the ESC's throttle signal pin into the output of the switch wire connected to the receiver or use the receiver battery pack option. The On/Off switch provides added safety and convenience when connecting the battery pack or finishing a flight.
Click for fullsize
       Post #: 61
RE: E-flite J-3 Cub 25 ARF - 8/15/2006 4:56:40 PM
Tall Texan
Status: offline
Greg,
This sounds neat except I not sure how you wired the on/off switch into the ESC. That would be nice to turn the ESC on/off after you have connected the battery. Would like to see how you did this. Do you simply use the ESC rcvr signal lead and plug it into the switch and then plug the switch lead into the throttle port on the rcvr?
       Post #: 62
