Glacier Girl -> RE: E-flite J-3 Cub 25 ARF (9/19/2006 11:48:29 AM)
Something else I did, just to be different, and because I didn't like the set up. Instead of the wheel collars and epoxy route listed in the manual to attach the two elevator control rods together, I put a Z bend on the left rod and used a crimp connector and silver solder to hold the rods together. There was a method to my madness. The right rod falls right in line with the servo arm, the left doesn't, so in pinching the rods together with the collars it would cause both to bind on the tubes as they were connected to the servo arm. By putting a Z bend in the left rod I was able to make it slide with little drag and line up with the right rod's direction of travel. The rods are strong enough that the Z bend won't affect it, and now there is less drag for the servo to overcome. Every little bit helps when making a servo work. Oh and I did it outside the bird, after marking the spots on the rods for the connection. Once it was soldered, it was just a matter of slipping the rods in the tubes from the cockpit side and sliding them into place.
