lthibault
QC, CANADA Status: offline
Hi FlyingGuy, Yes this type of plane is more demanding than a 3D Funtana or Cap; those almost take off and land by themselves!!! With this cub you'll notice a clear tendancy to go left if you do a premature take-off. Then things get worst if you hit the ailerons and stall even more... So again the routine would look like this: -Keep the elevator full up -Slowly increase power, keep her straight in the middle of the runway -As the plane pick up speed you'll see the wheels starting to bounce up, the plane will almost be air born -Release the elevator and the second the plane is leaving the ground hit the speed stick to pull it forward, not up, to gain airspeed. -In addition to this, you'll need to use the rudder to correct and prevent any tendancy, i.e. crosswind, etc. For landings I noticed that she comes down quickly and the propellor is a good break so I use a somewhat agressive descend and a quick balloon at the end. She may bounce but with the suspension it's ok. Good luck! I'm about to put my floats and try it on the water next weekend.
_____________________________
Luc
