Glacier Girl -> RE: E-flite J-3 Cub 25 ARF (10/9/2006 11:36:16 AM)
Well I finally got mine in the air. Sunday was beautiful, 70's and no wind, a real change from the previous rain and high winds it's been. Took her down to the local soccer fields and boy did those swamper tires work out, she just waded through the high grass like nothing. I'm positive it would have been a no go with the stock wheels. Only fault was she tracked right instead of left on take off, Which I probably made worse as I was planing on the left turn Cub's are noted for. Anyhow, she made a 90 degree turn and proceed to lift off. Whew. Ah but in the air, no dissapointment what so ever. 2 clicks of down elevator and she was trimmed. The big tires did not seem to affect her at all. Loops were nice and easy, aileron turns required only the slightest touch of up elevator to keep her level. Ok landing was different, ok it was a lot different from the warbirds I'm used to flying. A warbird is driven to the ground, not so the Cub. She just floated, so much so I did 2 go arounds trying to get her down. I ended up shutting off the motor halfway through the upwind turn and just left her glide in. Again the big tires proved their worth. She just rolled on the mains until the tail dropped down. Not a hint of nose over. Couple blips of the throttle and she waded through the grass back to me. Oh and that was with the 10x6 wood prop. Was more then enough and speed was around 45 mph, judging from flybys next to the highway. A tad bit more then half throttle had her cruising at what I judged to be accurate speed, and as I found out on landing, just the prop ticking over was enough that she would not come down unless commanded to. And quiet, was a whisper in the air, even full throttle and she would only make a slight whine as she went by at head height. BIG SMILES!!!!!!![:D][:D][:D]
