RE: Stop using CA glue for your tires
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Stop using CA glue for your tires Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Stop using CA glue for your tires - 7/15/2006 5:45:14 AM
---RC PiNYoT---
Status: offline
what's the difference between the black and the white stuff?
(in reply to Mike SVOR)
       Post #: 26
RE: Stop using CA glue for your tires - 7/15/2006 2:32:44 PM
Dawman
Status: offline
quote:
ORIGINAL: _RC_PiNYoT_
The color .
_____________________________
Caster Team Member `09
AB Mechanical - for all your heating and A/C needs
(in reply to ---RC PiNYoT---)
       Post #: 27
RE: Stop using CA glue for your tires - 7/15/2006 2:51:43 PM
bentgear
Status: offline
One thing that seems to be getting left out on the tire/rim prep is to remove the mold flashing that appears on some tires, this prevents the tire from laying completely on the rim. When you sand, grind, etc. the seating surface on the rims you are only wanting to break the glazed surface, not make it real ruff. Reclean the rim after breaking the glaze. CA is strongest on non porus surfaces when it only forms a very thin layer between 2 relatively smooth surfaces.
Ed M.
Did you bother to Read The Fine Manual yet?
(in reply to Dawman)
       Post #: 28
RE: Stop using CA glue for your tires - 7/16/2006 1:38:28 PM
Mike SVOR
Status: offline
no matter how you prep your tires/rims, when you hit a rock hard enough, it will cause the plastic rim to flex slightly. CA glue doesn't flex too well on plastic.
Either way, I'm done with CA glues from now on.
I'm just throwing this tip out there in case anyone wants to know about it. If you're a true believer of CA glue, fine, I don't care.
I am telling you this though, Marine 5200 is a MUCH better bond between rubber and plastic than CA glue.
Use it if ya want.
I know what I'll be using.
I can fly the box it came in.
Raptor Titan 50, Extra 300 w/OS 1.08, OFNA GT.21, HoneyBeeFP, Blade400, HouseofBalsa P-51
(in reply to bentgear)
       Post #: 29
RE: Stop using CA glue for your tires - 7/16/2006 2:27:36 PM
Dawman
Status: offline
If you hit a rock hard enough you don`t have worry about the rim flexing , it will be broke .
Well , I suggest you go tell all the racers in the world to switch to marine 5200 so they can hurry up and get it before it sells out .
       Post #: 30
RE: Stop using CA glue for your tires - 7/16/2006 4:20:57 PM
RCtruckRacer
Status: offline
I think it was cool to share the tip. Too bad there's always someone that has to tell you to go jump in a lake. However, I'll be sticking with CA, since I often need to do a quick repair at the track and mostly can't wait 3 days for it to bond. Even with a new set of tires, I am usually on them well before 3 days. I've also never had a complete failure since I've been into RC (now that I've said that, no doubt I will now), so I can't see a need to 'upgrade' here. But thanks for the tip, and keep 'em coming!
Some people see the glass half full. Others see it half empty. I see a glass that's twice as big as it needs to be.
My opinions are my own, and are not necessarily those of RCU
       Post #: 31
RE: Stop using CA glue for your tires - 7/17/2006 12:24:35 AM
gasrc
Status: offline
quote:
ORIGINAL: kx250ryder
The key is using hobby grade super glue, such as the stuff from Team Losi mentioned above. Yeah, you are going to pay 8 bucks a bottle, but it works. I was using cheapy grocery store stuff and constantly re-gluing my tires too. I tried the good stuff on my latest set of tires, and now my tires don't come off anymore.
I haven't read all the post in this thread, but the REAL KEY is technique. I use hobby store brand CA with great results. Peple are just way too impatient when it comes to properly gluing tires. I absolutely hate doing it myself, but I take my time up front to do it right, so I won't have to do it again. I do it in several steps and maticulously go areoung the tire looking for the smallest seperation. Or some occations after a lot of use, I may see a little openning. I just throw in a maintainence drop, and it's all good. Poor tire gluing can lead to a lot of irritation when you are out trying to have fun.
It's like:
* going fishing with rusty hooks and old line.
* going drag racing with tire belts showing
* shaving with with an old blade
* marrying a thin girl that you know loves sweets
(in reply to kx250ryder)
       Post #: 32
RE: Stop using CA glue for your tires - 7/17/2006 6:44:02 PM
bennyblanco
Status: offline
i think this is a good tip for us bashers so i thank you for the tip!!!!!
< Message edited by savage.27 -- 7/17/2006 6:45:01 PM >
Revo rb523::: Jato tm18::: Team Magic g4 tz.18 :::
Spektrum 3.0:::Sportwerks Mayhem buggy stock:::
(in reply to gasrc)
       Post #: 33
RE: Stop using CA glue for your tires - 7/17/2006 10:34:25 PM
slodsm
Status: offline
If I didn't know better, I would think Mike was working for them or getting a commision the way he is selling this stuff.
Count me in as one of the 5 people who must know how to glue a tire because I have never had one come off on me and I live on the track.
Jay Sensing, Car Moderator
Airing it out on the east coast.
(in reply to bennyblanco)
       Post #: 34
RE: Stop using CA glue for your tires - 7/17/2006 10:50:39 PM
Mike SVOR
Status: offline
quote:
ORIGINAL: slodsm
quote:
Please resist the urge to curse, flame, degrade, insult or embarrass someone in your post. We encourage the free flow of your ideas, but believe that they can be communicated (and received) much more effectively if you keep things civil. If you have to vent, take it offline. We carefully monitor posts and will ban individuals who engage in offensive conduct within the forums.
Dude, I'm gona bite my tongue on this one cause I like hanging out on the large scale car board. But you're out of line.
< Message edited by Mike SVOR -- 7/17/2006 10:54:59 PM >
(in reply to slodsm)
       Post #: 35
RE: Stop using CA glue for your tires - 7/17/2006 10:57:49 PM
slodsm
Status: offline
I am out of line?
In exactly what portion am I out of line? I helped write the rules for this board.
       Post #: 36
RE: Stop using CA glue for your tires - 7/17/2006 11:12:46 PM
Dawman
Status: offline
Mike where did Slodsm curse, flame, degrade, insult or embarrass in his post ? If anything he said seemed attacking or hurt you , get over it . You can`t glue tires so you use marine 5200 , ok we get it , it works for you . Some people actually can make a miracle happen and glue their tires . You shared a tip that works for you , thankyou for that . If someone curses or flames you it will be taken care of as mods check through the threads for such .
       Post #: 37
RE: Stop using CA glue for your tires - 7/17/2006 11:28:01 PM
Mike SVOR
Status: offline
quote:
ORIGINAL: Dawman
Pfff, please.
Buddy, I'm "over it".
quote:
ORIGINAL: Dawman
Let me help you out here:
Please resist the urge to insult someone in your post. "If I didn't know better, I would think Mike was working for them or getting a commision the way he is selling this stuff."
I take that as an insult. As I stated earlier in this thread, if you have good luck with CA glue, great, I don't care, use it if you want. And at no point did I direct anyone to any 1 store to buy it. Like I'm some hobby store owner who just got in a shipment of 5200.
Please resist the urge to degrade, or embarrass someone in your post. "Count me in as one of the 5 people who must know how to glue a tire because I have never had one come off on me and I live on the track."
Like I've never glued any tires on before. I've been doing this for 25 years. I've glued grasshopper tires onto road wizard rims in the mid 80's
and finally: We encourage the free flow of your ideas.....
I thought I'd post up some results for others to look at. But of course, there has to be the regular internet commandos that know everything and everyone else doesn't know jack.
Party on folks. Have fun on the 1/8 scale board.
Mike
< Message edited by Mike SVOR -- 7/17/2006 11:29:55 PM >
       Post #: 38
RE: Stop using CA glue for your tires - 7/17/2006 11:38:50 PM
Dawman
Status: offline
Ya , it looks like your over it . Who on here says they know everything ? If they did I`d like to meet them . What do you expect coming on a forum and telling everyone you can`t glue tires using ca ? I know you ment it as a tip but come on you left yourself wide open for comments . Just because you took it as an insult it is not a curse, flame, degrade, insult or embarrass .
< Message edited by Dawman -- 7/17/2006 11:41:08 PM >
       Post #: 39
RE: Stop using CA glue for your tires - 7/17/2006 11:54:43 PM
Mike SVOR
Status: offline
quote:
ORIGINAL: Dawman
Ahhhh, Is that what happened. I get it now.
See, I thought I came onto a forum giving folks an alternative to CA type glues.
I didn't know that it really meant i'm an idiot that doesn't know how to glue a tire to any car I've ever owned.
Wow, thanks for showing me the light.
Next time, I'll post a thread stating that I'm an idiot that doesn't know how to make something work then ask for permission to use a particular product to cure it.
       Post #: 40
RE: Stop using CA glue for your tires - 7/18/2006 12:00:23 AM
