Ian.W
Joined: 6/22/2003 From: Essex, UNITED KINGDOM Status: offline
Well, the model was originally flown on an OS 160, which is what you see in the pics (chris putting it through its paces). The UK distributer, Daniel Roser of Freestyle RC is also using an OS 160. It can also be used with an YS 140 and the 160, which i can tell you all is one heck of a motor (turns an 19x8w, and ooh so smooth). However, ive gone for somthing slightly more enviromentally friendly Hacker Power! To be a bit more specific im going to be using a Hacker C50-14xl Acro Competition. This is a top of the range motor, best money can buy, for 2m models, all the top pattern pilots use it. It comes at price, but when added up against a YS 160/hyde/haitori setup, its about the same. with 10s1p Flightpower 5000 packs, and a 22x12 prop, i should be pushing 2.5Kw!!! hopefully all that power will be helpfull as an E setup will weigh approx 1kg more than the IC setup (dry), about 2lbs. As for small gassers, personally i wouldnt reccomend one, but if i did have to, a ZDZ 40 or a Evo/MVVS 45 MAG (magnesium casing, much lighter), both with lipos on the ignition More details and pictures soon!
< Message edited by Ian.W -- 7/13/2006 9:25:59 PM >
_____________________________
Ian Watson Team Flightpower
