DiscoWings
LA, USA Status: offline
quote:
ORIGINAL: Ian.W you wont need 12s, with my 10s setup (flightpower 10s1p 5000) i have more than enough power.... or at least i did ahh no, I know what I need neu motors are more effcient at higher voltage and support 12s packs. Also the low RPM will let me swing a 22x10 prop and produce good power at around 5500-6000 RPM. I have a hacker c50 12XL in a ultralight giles on a 9s3p setup pulling 53 amps static on a 20x10 apc-e prop. It does pretty good but the hacker motors aren't as strong as the neu motors and if I could I would run 12s on them but they would cook... sorry to hear about your yak
_____________________________
"Hi,You are 100% correct but are also 100% wrong... " - rcflip
