RE: Extreme Flight RC Yak 54 - 74 inch!
Tower Hobbies
Logged in as Guest
Users viewing this topic: redflyboy122
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Extreme Flight RC Yak 54 - 74 inch! Page: <<   < prev  83 84 85 [86] 87 88 89 90 91 92   next >   >>
Login
RE: ... - 4/5/2008 8:55:36 PM
GregT882762
Status: offline
NO not inverted, should i,tru turn up front xoar 18x 6 everything else in canopy
(in reply to nitro wing)
       Post #: 2126
RE: ... - 4/5/2008 8:57:51 PM
nitro wing
Status: offline
Yes,some will disagree with me,but do it inverted and you will get a close CG
(in reply to GregT882762)
       Post #: 2127
RE: ... - 4/5/2008 9:05:48 PM
GregT882762
Status: offline
Ok going out to try it now back with info ina few minutes
       Post #: 2128
RE: ... - 4/5/2008 9:13:25 PM
Michaelh
Status: online
Im curious to here the results on that.
_____________________________
More info on Saito's http://saito-engines.info/
Club Saito #542
       Post #: 2129
RE: ... - 4/5/2008 9:18:51 PM
GregT882762
Status: offline
well a little better battery is strapped to wing tubegoing through plane inverted seems to be around 6.5 maybe a tad more back to get it cenetered?
(in reply to Michaelh)
       Post #: 2130
RE: ... - 4/5/2008 9:33:58 PM
nitro wing
Status: offline
I am used to flying with lots of pitch authority and would fly it a at 6.5
I dont recommend it though,just get that battery further up for initial flights.The Yak rotates agressively already,no sense crapping your pants on maiden.
If you have 40 degress elevator throw,be sure to get at least 50-60% expo,or it will be an animal.I think I have 80% on full throw.
       Post #: 2131
RE: ... - 4/5/2008 9:44:05 PM
GregT882762
Status: offline
OK so u think close to 6 is better
       Post #: 2132
RE: ... - 4/5/2008 10:01:17 PM
nitro wing
Status: offline
Yeah I 'd try to get it to 6 or 6.25 and see how it feels to you.Do this with out fuel in tank
       Post #: 2133
RE: ... - 4/5/2008 10:02:09 PM
Michaelh
Status: online
40 degree thats weak Nitro But I did tone mine down to 45 and not the suggested bevel to bevel wich I measured at 60 degree's !
Flew it like that for a while and was like an airbrake, will mess with you and slow you down too much if your not used to it. Which Im still not.
Club Saito #542
       Post #: 2134
RE: ... - 4/5/2008 10:24:37 PM
GregT882762
Status: offline
half tank
       Post #: 2135
RE: ... - 4/5/2008 10:27:31 PM
Michaelh
Status: online
empty!
Club Saito #542
       Post #: 2136
RE: ... - 4/5/2008 10:45:26 PM
GregT882762
Status: offline
k
       Post #: 2137
RE: ... - 4/5/2008 11:59:54 PM
nitro wing
Status: offline
I probably have 50 degrees or so in mine,I asumed that Cameron had about 40 max to start with,maybe less,just wanted to point out that if he has big throws to make sure he has expo to match
       Post #: 2138
RE: ... - 4/6/2008 12:05:32 AM
GregT882762
Status: offline
yes i believe about 40 right now hoping to maiden soon maybe this coming week our field is flooded right now from all the rain from the last week,we got pounded,looks like i might have to add just a little up front,still leaning more towrtads the rear at wing tube or 6.45 so a touch more then a full tank should be good thanks for all the help ,i double checked my expos on low and high and have them set at 60 low 70 high
       Post #: 2139
RE: ... - 4/6/2008 12:10:41 AM
