RE: Extreme Flight RC Yak 54 - 74 inch!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Extreme Flight RC Yak 54 - 74 inch! Page: <<   < prev  83 84 85 86 [87] 88 89 90 91 92   next >   >>
Login
RE: ... - 4/21/2008 6:05:58 PM
nitro wing
Status: offline
Hmm. I am using the Bisson also (stock) I dont have any rpm numbers but mine is pulling the Yak with ease.using coolpower 10%.try a different fuel maybe.
< Message edited by nitro wing -- 4/21/2008 6:06:24 PM >
(in reply to hornet dave)
       Post #: 2151
RE: ... - 4/29/2008 11:14:20 PM
RJConnet
Status: offline
Hey guys, I need help trimming my 74" yak, it is B46 powered and weighs 12 & 1/2 Lbs. Trimmed for level flight upright the elevator counter balances are about 3/32 In. lower than the leading edge of the elevator so it is carrying a little up elevator for level flight. You would at first think it's probably a little nose heavy, however it balances between the forward and aft figures given in the manual and when the plane is inverted it goes into a very shallow climb. When throttle is closed in upright flight the nose does not want to drop and the plane will eventually stall if left alone. I really don't like having to use a little down elevator to get it on the ground. The engine thrust line is now determined by the offset built into the firewall i.e the engine is mounted at 90 degrees to the firewall (up and down). So what do I need to do, a little up-thrust in the engine maybe, any advice will be appreciated.......RJ
(in reply to nitro wing)
       Post #: 2152
RE: ... - 4/30/2008 12:03:26 AM
xtraflyr
Status: offline
quote:
ORIGINAL: RJConnet
Well it could also be the stab incedence? If you set that to zero then a little up thrust seems to be the fix..
Check the incedence,then just try a little bit up up thrust.. trial and error..
Cya
Frank
_____________________________
www.njjf.org
www.njjf.freeforums.org
(in reply to RJConnet)
       Post #: 2153
RE: ... - 4/30/2008 12:21:42 AM
nitro wing
Status: offline
Its the stabs,mine was the same.Get an incidence meter and do the the necessary adjustments,its easy.
You cant measure or eyeball it,its only one or 2 degrees,The stabs are likely angled up a bit at the LE,which causes a down pitch.
You will never trim or enjoy the airplane if you dont take the time to slot the holes a bit and set it up 100%.Somewhere in this thread is a how to, with pics.Good luck.
It flies much better after the fix.
(in reply to xtraflyr)
       Post #: 2154
RE: ... - 4/30/2008 5:03:54 PM
BarracudaHockey
Status: offline
Fixing the stab is pretty easy, I have the document from EF if you need it. Mine was 2.5 off on one side and .5 off on the other. Just the nature of low cost, over seas, mass manufacturing.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
       Post #: 2155
RE: ... - 4/30/2008 5:20:14 PM
rcgood
Status: offline
Maybe that's why I never enjoyed mine. I just did not like the way it flew period and was always confused when people would rave how good it flies. I assumed coming from EF and the price you pay, it wouldn't have that problem. I wish I would've known about this before it went in so maybe I would fix the problem. Oh well...now I'm looking for something else to put my gear in. Really like the looks of it though.
(in reply to BarracudaHockey)
       Post #: 2156
RE: ... - 4/30/2008 5:35:16 PM
RJConnet
Status: offline
Barracuda Hockey,
I would like to see that document you mentioned if it's not too much trouble.............RJ
       Post #: 2157
RE: ... - 4/30/2008 6:44:51 PM
therupman
Status: offline
BarracudaHockey,
I'd like to see that document,also.
Bob Ruppel
THERUPMAN@aol.com
       Post #: 2158
RE: ... - 4/30/2008 6:48:23 PM
BarracudaHockey
Status: offline
Sent to both of you.
I was so happy with my new one (my red one got destroyed by a freakin foamy mid air) I had to get a new canopy for my heli to match it
Click to see fullsize image.
Click for fullsize
< Message edited by BarracudaHockey -- 4/30/2008 6:50:25 PM >
(in reply to therupman)
       Post #: 2159
RE: ... - 4/30/2008 8:15:06 PM
RJConnet
Status: offline
Barracuda Hockey,
Thanks a bunch, now all I have to do is buy, beg, borrow, or steal an incidence meter............RJ
       Post #: 2160
RE: ... - 4/30/2008 9:04:52 PM
redflyboy122
Status: offline
hey barracuda while you are sending it i would love a copy as well if you are able!!
cody.stauffer@und.edu
thanks alot!
       Post #: 2161
RE: ... - 5/1/2008 4:27:29 AM
FLYMIKE
Status: offline
quote:
ORIGINAL: RJConnet
If your incidence is on...try adding down thrust.I put about 1.5 degrees on mine and it flew way better....I had the same problem and the incidence wasnt off...
< Message edited by FLYMIKE -- 5/1/2008 4:28:55 AM >
       Post #: 2162
RE: ... - 5/1/2008 7:26:12 PM
FrankFuss
Status: offline
Barracuda
Can you also send me a copy of the document about fixing the stab incidence? Thanks. I have a new 74" Yak sitting in the box in my shop ready for the build. I hope I can learn from all the experience in this forum and avoid any problems.
Frank
< Message edited by FrankFuss -- 5/2/2008 3:19:24 AM >
       Post #: 2163
RE: ... - 5/1/2008 9:20:03 PM
BarracudaHockey
Status: offline
Sent it to everyone who asked.
(in reply to FrankFuss)
       Post #: 2164
